battery for B5100E
/ battery for B5100E #1
stearnser
I just got a B5100E and I need to replace the battery (the one in it is 365 CCA and is dead). The owners manual doesn't say much about what type of CCA I should be looking for. I would rather not go to the Kubota dealer to get the battery unless I have to. Anybody got any advice or specifics (size, model numbers, etc). Thanks.
/ battery for B5100E #2
I have an Interstate battery in my B7100. They were the only ones around here that had the small size I needed with enough cranking amps for a diesel engine. My Kubota dealer only uses these as well. I use my tractor all year and with well below zero temps I could not get away with using a less powerfull battery.
Hope this helps
Scott
/ battery for B5100E #3
optima all the way
PS welcome to TBN!
/ battery for B5100E #4
I went through the same thing 3 years a go with my B5100. I could not find the right type of battery at my local farm and ranch supply or at the auto parts store that carried Interstate batteries. I finely settled for a Duralast Gold battery I found at a second auto parts store. Other then what I paid for the battery I can not complaints about it.
If you still have not found a battery and would like to know what model I have let me know. I will take the hold down bracket off mine and get it for you.
Rsislo
Thanks, this is a great forum, helpful and informative. Rsislo, I sent you a PM.
2017 Ford Fusion Hybrid Sedan (A64557)
2017 Ford Fusion...
Ford Pickup Truck Bed (A64556)
Ford Pickup Truck...
2011 18ft. Maxey Flatbed Utility Trailer (A64194)
2011 18ft. Maxey...
Bigfoot (A64557)
Bigfoot (A64557)
2001 Freightliner FL112 T/A Wet Kit Day Cab Truck Tractor (A64556)
2001 Freightliner...
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
