Battery experts needed - substitute 24F for 24 to get positive terminal forward.
   / Battery experts needed - substitute 24F for 24 to get positive terminal forward. #21
I guess folks are wondering why I went with the Walmart unit. 5 year warranty and I can buy a lot of them for the price of the others. Turns out my bad battery is not totally bad due to a very corroded connection. Corrosion was inside where I could not see it. I'll use it to run my 12V fueling station - should be good for a long time.
Again thanks for the help.
Now having said that I have been studying solar power with battery backup. That's where you need a very high density deep cycle and pays to go premium from what I am reading.
If the new battery works well over the winter you should have your answer.
I have looked at solar for some time and my thought is selling back to the power company/grid is the best compromise. I would have a small bank of batteries for emergency use and buffering. Buying a bunch of these large batteries isn't cost effective yet unless you are remote and out of reach of power lines.
   / Battery experts needed - substitute 24F for 24 to get positive terminal forward. #22
I have bever paid the extra for an AGM or optima battery in anything other than a motorcycle. So no experience with full sized batteries. Just cannot justify the cost. The battery in my old L3400 that I sold to dad, still has the OEM battery in it from 2005.
YUP, In my opinion, full size AGM/Optima batteries are NOT worth their ridiculous cost!
Buy a decent quality, lead/acid battery, and keep a quality trickle charger ( Deltran or solar ) on it when you expect your machine to sit a week or more.
You can buy TWO or more lead/acid batteries for the price of one of those fancy "forever" batteries.
Your TWO batteries should last at least a total of 16 years. I think it rather unlikely that you would get 16 years out of any AGM/Optima battery.
   / Battery experts needed - substitute 24F for 24 to get positive terminal forward. #23
For what it's worth, I did a Walmart battery in my ct235, and cleaned up the connections, about a year ago. I haven't had to charge it or trickle it, yet it regularly sits for 2 or 3 weeks at a time.
   / Battery experts needed - substitute 24F for 24 to get positive terminal forward. #24
Cleaning the posts and clamps once per year would save the needless replacement of literally thousands of batteries.
   / Battery experts needed - substitute 24F for 24 to get positive terminal forward. #25
I actually have a lawn tractor battery in my little JD. Have the same battery in my 99 Mustang and on my gate openers. The one in the Mustang went bad after 5 years and got replaced with the same for another $25. :) I replaced the ends with heavy duty eyelet connectors. I always smear petroleum jelly on my connectors to keep corrosion from happening.
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
2007 Ford F-150 (A55973)
2007 Ford F-150...
2019 Land Rover Range Rover Sport AWD SUV (A55853)
2019 Land Rover...
2019 Kohler 50REOZK 50 kW Diesel Generator (A56857)
2019 Kohler...
JCB Forks and Frame Skid Steer Attachment (A56857)
JCB Forks and...
2016 FORD F-550 UTILITY / MECHANICS TRUCK (A57880)
2016 FORD F-550...
