Battery Definitions
/ Battery Definitions #1
bigpete
Delaware
JD 4110 HST w/410 Loader and 60
I hate to post another batter thread with a "Battery Recommendations" thread just below. That one has to do with golf carts, so I figure you folks wouldn't mind.
After reading about other battery acid vs. radiator nightmares in another thread, I have decided to go ahead and upgrade as soon as it is practical. Several people have been talking about "Optima" batteries, which seems like a great design. Most likely that will be my upgrade, but I'm a little in the dark about some of the terminology, i.e. Deep Cycle, etc. Any battery experts out there? I'm operating a 2003 4110.
/ Battery Definitions #2
Pete I agree the Optima battery is the way to go. I installed one in my New Holland when the original battery started spewing acid..
Typically a deep cycle battery is used for an application such as an electric trolling motor on a fishing boat. They are meant to be almost completely discharged before recharging without adverse problem to the battery itself.
I might suggest visiting the FAQ page at the Optima site. There is a lot of interesting info there click here
/ Battery Definitions #3
BigPete,
Your machine uses the group 51R series which is a yellow top
version from Optima. I did the change over a few months ago
on my 4100 for a major piece of mind. Costco might have the Optima 51 R for less...funny thing its the same size as a Honda civic (newer models)
Duc
Thanks, guys. I will study up. this is a piece-of-mind upgrade, too.
Duc, I read that the battery you recommend is a yellow top/deep cycle. I don't think the stock batteries are deep cycle. Any reason the yellow top is recommended? Is it just because the battery will sit for a few weeks at a time during the down season? I don't typically run much of a load or run lights off the battery with the engine off.
/ Battery Definitions #6
/ Battery Definitions #7
Hi BigPete,
I was looking for a solution for 6 months when someone sent me this link below, it mentioned Optima offering a group 51 battery. I literally ran to the nearest supply outlet near me ( Pep boys) who had it in stock...it cost me $125 but I will never regret that at all. Your new machine my not be a problem because maybe they addressed it with a better battery?
As far as I know yellow is the only offering thus far in a Group 51 R size...its got a little more punch (CCA) and starts it right up in the cold, but best of all no worries.
Duc
http://www.jci.com/CorpPR/Releases/battery/release626.asp
/ Battery Definitions #8
I would go with the "redtop", 800cca, as opposed to 500cca for the group 51 "yellow top". You can't go wrong getting the biggest/strongest battery that will fit in your space. Roger-Scotty always recommended the "redtop".
/ Battery Definitions #9
</font><font color="blue" class="small">( I would go with the "redtop", 800cca, as opposed to 500cca for the group 51 "yellow top". You can't go wrong getting the biggest/strongest battery that will fit in your space. Roger-Scotty always recommended the "redtop". )</font>
Problem is it will only fit a Group 51 - you are limited to space
and I already tried that with no luck...Yellow is fine and more than adequate...the stock battery is 435cca, the yellow battery is at 500cca...I know originally they didn't offer a group 51 in a red top, but it could have been ( very) recently introduced...its more than enough battery for this machine thats for sure, it comes down to price after that and if its available...
Duc
/ Battery Definitions #10
Just a thought but you guys still needing Optima batteries may want to check your local AutoZone stores. They started stocking some of the Optima batteries shortly after I installed one in my New Holland. The prices looked good also.
/ Battery Definitions #11
Sams's club is also selling the Optima's under the Champion brand name.
Andy
2014 GMC SIERRA 1500 (A62613)
2014 GMC SIERRA...
2018 HINO 338 KNUCKLE BOOM TRUCK (A63276)
2018 HINO 338...
CLARK FORKLIFT (A63291)
CLARK FORKLIFT...
2018 Kenworth W900 Ext. Day Cab (A62613)
2018 Kenworth W900...
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
