battery crud?
   / battery crud? #11
This just happened to my new 3016 as well. It was a 2012 left over sitting in the lot for a year. Try not to use baking soda on the battery itself as if this battery has poor fitting posts or caps, some of this could weep into the battery itself and electrolyte and baking soda is not a good mix. Had to take it all down, clean up the corroded terminals, wire brush the battery box, Por 15 brushed onto the battery box as well as the hold down rod. Sprayed the terminals and posts with Battery Saver and used the felt disks under the terminal connections. If it does it again, this battery is gone and a Die Hard is going in. Last one was 18 years old and still going strong.
   / battery crud? #12
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
UNUSED FUTURE FT-180H HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
1408 (A57192)
1408 (A57192)
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2018 John Deere TX (A53317)
2018 John Deere TX...
