battery charger?
/ battery charger? #11
Neal - you reminded me of the charger brand we use. Most of my family have had good service from the <A target="_blank" HREF=http://www.batterychargers.com/top.htm>Schumacher</A> products. Oddly enough, we always find them at places like K Mart. They are quite weighty, which we always assumed meant more copper in the transformers.
We've only use the trickle chargers so far; this has been good info for me regarding the starting functions.
/ battery charger? #12
I use a portable trickle charger that I bought as Sears. I can be used on cars/trucks/lawn equipment etc. It mounts next to the battery and connects to the + and - terminals. The other end has a 3 prong 110 plug that I plug into and outlet in the garage. I only use this in the winter to keep the battery up to snuff. Works great and it only cost $20.00. I have one from my lawn tractor and for my 4110.
Mark
/ battery charger? #13
I stay away from the Wal-Mart chargers. I bought two for charging trolling motors (about $25 each, IIRC). Both of them first had problems with the contact in the positive cable (melted the plastic--could have caused a fire), then after some period of time the automatic charging function fails to work (it never fully charges the battery--put it on my big Sears charger, they charge right up, so it wasn't the battery).
I buy other stuff at Wal-Mart, but won't buy a charger there again. Just my experience.
-Chris
/ battery charger? #14
When i mentioned safety, I was actually thinking along the lines of start / boost in emergency situations, but since you mention it, you might want to make sure that the charger you choose has some sort of built in circuit breaker or fuse. ( most I have seen have an internal breaker, or thermal breaker. )
Soundguy
/ battery charger?
Neal and Mark,
Thanks for the lead on Schumacher products. I have found a Schumacher 125/15/2 automatic charger at a local "discount" farm supply/hardware store. The charger will suit my needs and, at $70, is $10 off the price listed at the Schumacher Web site.
2014 FREIGHTLINER CASCADIA (A60736)
2014 FREIGHTLINER...
Iranch IRGC40 High End Golf Cart (A60463)
Iranch IRGC40 High...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
2015 Caterpillar CB24B (A60462)
2015 Caterpillar...
Champion Vibratory Roller (A60462)
Champion Vibratory...
Echo SRM2620 Gas Trimmer (A60352)
Echo SRM2620 Gas...
