Battery cable size
/ Battery cable size #1
kayco53
British Columbia
Kubota L2500
I have a kubota L2500dt.Wondering what gauge postive cable I should run to the starter.Know the length already.But I 'am 200+ miles from the tractor so awkward to check the gauge of wire.
Thanks
/ Battery cable size #2
Just go to an auto parts or Wallmart and buy your correct length from car cable stocks.
If a cable can start a car it will do for the tractor. It can never be too big a gauge.
It is one case where bigger can be better.
/ Battery cable size #3
Car cables likely won't be bigger than 4 gauge. Tractor cables probably shouldn't be smaller than 1 gauge. 4 is much smaller than 1.
/ Battery cable size #4
Heavier is better. The chassis return cable or what is called "ground" is every bit as important as the cable to the starter. Many machines use a contorted path of bolted together sections of sheet metal etc as the return path. Odds are you will be amazed at how much faster the engine cranks with 2/00 cable. With a new " ground" cable ran direct from the battery to a starter mounting bolt.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2000 Sterling L9513 Winch Truck (A63118)
2000 Sterling...
JMR TREE BOOM (A61572)
Rotomec PHD 300 (A64126)
Rotomec PHD 300...
2023 John Deere 333G for Parts (A61306)
2023 John Deere...
2007 GMC C4500 Service Truck (A62679)
2007 GMC C4500...
