Battery cable size
/ Battery cable size #1
kayco53
Member
British Columbia
Kubota L2500
I have a kubota L2500dt.Wondering what gauge postive cable I should run to the starter.Know the length already.But I 'am 200+ miles from the tractor so awkward to check the gauge of wire.
Thanks
/ Battery cable size #2
Just go to an auto parts or Wallmart and buy your correct length from car cable stocks.
If a cable can start a car it will do for the tractor. It can never be too big a gauge.
It is one case where bigger can be better.
/ Battery cable size #3
Car cables likely won't be bigger than 4 gauge. Tractor cables probably shouldn't be smaller than 1 gauge. 4 is much smaller than 1.
/ Battery cable size #4
Heavier is better. The chassis return cable or what is called "ground" is every bit as important as the cable to the starter. Many machines use a contorted path of bolted together sections of sheet metal etc as the return path. Odds are you will be amazed at how much faster the engine cranks with 2/00 cable. With a new " ground" cable ran direct from the battery to a starter mounting bolt.
Landhonor SAD-12-23C Skid Steer Mount Auger (A62679)
Landhonor...
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
KBH Tender Trailer (A63688)
KBH Tender Trailer...
2016 Doyle 10T Tender (A61307)
2016 Doyle 10T...
Yale Forklift - NO RESERVE! (A63688)
Yale Forklift - NO...
New/Unused Landhonor Hydraulic Quick Attach Auger (A65583)
New/Unused...
