Battery based electric vehicles of today and tomorrow.
Status
Not open for further replies.
   / Battery based electric vehicles of today and tomorrow. #4,971
In the thread about the Big Boy, I thought it said they put the diesel electric there for the braking to save the brakes on the Big Boy, not so much because it was safer, but because the brakes on the Big Boy would be insanely expensive to replace.
Brakes.... interesting topic.
The question I asked in a showroom years back (not really expecting an answer) was "Since hydraulic disc brakes on ICE cars tend to regularly seize up, here in salt-country, has anything different been done with the hybrid's brake design ?". Same question applies for EVs obviously.
Rgds, D.
   / Battery based electric vehicles of today and tomorrow. #4,973
Rgds, D.
Brakejobs is bread and butter for workshops, car manufacturers are under pressure from dealers to keep revenue up, some of the EVs has often some ridiculous "services" to keep dealers from getting to upset. Suppose Tesla will be one of the first to find better solutions for brakes, on a EV ordinary brakes will almost be emergency only brakes so it could be made very different.
What evidence do you offer in support of your conclusion? You say there is a 50% failure rate at 100,000 miles no matter the cost is 100% covered for 8 years/100,000 miles? Or 10 years/150,000 miles in some states?
Nissan's battery is atypical. And apparently GM is also flying fast and loose with their battery.
Tesla has had battery failures prior to 100,000 miles. But Ford, GM, FCA, BMW, Porsche, Mercedes-Benz, Toyota, Hyundai, Kia, all have had similar failure rates with engines.
At 8 years my Tesla battery has 95% of it's original capacity.
That shows awesome longevity. What is the total miles on your Tesla?
   / Battery based electric vehicles of today and tomorrow. #4,975
I'll clarify.
I didn't say anything about failure rate. I said "An EV @ 100k, I'd allow for 50% of the battery cost.".
As in, I would...... not normal behaviour today, as I'm more fiscally conservative than even many of my parent's generation.... so my repair cash is set aside well ahead of time.....
At this point, I view HV packs (assuming no manuf defects) as no more that 200k mile items. I'll modify my gut feel on that as time rolls along.
Never claimed ICE engines as failure free either..... simple supply/ demand works in their favour at the moment.... other than a chronically bad design, the option of get a low-mile used engine from a wrecking yard (rear-end write-off) is viable today.
As EVs get written off in crashes, more HV packs and motors/controllers may be available in a similar fashion, but I expect the availability is low today.
(And No, :cool: I'm not saying EV electric motors have high failure rates either).
Rgds, D.
   / Battery based electric vehicles of today and tomorrow. #4,976
My user manual says for Maintenance :
Service Intervals
Your vehicle should generally be serviced on an as-needed basis. However, Tesla recommends the following maintenance items and intervals, as applicable to your vehicle, to ensure continued reliability and efficiency of your Model 3.
• Brake fluid health check every 2 years (replace if necessary).
• A/C desiccant bag replacement every 6 years.
• Cabin air filter replacement every 2 years.
Clean and lubricate brake calipers every year or 12,500 miles (20,000 km) if in an area where roads are salted during winter
• Rotate tires every 6,250 miles (10,000 km) or if tread depth difference is 2/32 in (1.5 mm) or greater, whichever comes first
So that's something I'll be doing once a year, in spring when I switch my winter tires for summer one. Like you said, they are used only in emergency situation (like two wolves crossing a road right in front of me last weekend!) so they need to be taken care of.
Unlike my ICE vehicles, I don't have to follow a maintenance schedule for extreme weather (where almost every intervals are half of the normal intervals), which is welcomed.
   / Battery based electric vehicles of today and tomorrow. #4,977
Service Intervals
That sounds about right (for all vehicles up here, not just EVs).
Rgds, D.
   / Battery based electric vehicles of today and tomorrow. #4,978
Service Intervals
Diversion.
As in, Power, not Thread wander :cool:. When the Bolt hv pack is at 100%, per California's description, electric braking action changes/drops off. (Makes sense to me).
I don't know what Tesla is doing for Power Diversion, understanding it may vary by model and year.
Back-emf from the motors has to be dissipated somewhere when used for braking, so if it's not going into a Full HV pack, what happens on the T's ?
You could direct it towards Cabin Heat, if it's being called for, but other than that..... ____________ ?
Rgds, D.
   / Battery based electric vehicles of today and tomorrow. #4,980
Diversion.
Rgds, D.
Regenerative braking is not available or reduced when the battery is close to 100% or if it's too cold.
Status
TEST YOUR BID BUTTON! (A58375)
TEST YOUR BID...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
New/Unused CFG Industrial QK20R Mini Excavator (A57453)
New/Unused CFG...
2008 Genie GTH-844 Telehandler (A57453)
2008 Genie GTH-844...
500 BBL WHEELED FRAC TANK (A58214)
500 BBL WHEELED...
2015 FORD F-250 SUPER DUTY (A58214)
2015 FORD F-250...
