Batteries -- what is the dif?
   / Batteries -- what is the dif? #1
DrRod
Platinum Member
Ellicott City, MD - Farm in Orbisonia PA (south ce
John Deere 4110
With three ATVs it seems I'm buying batteries with unsettling consistency. The dealer has plenty of options for $120 but Amazon and Rocky Mountain ATV have plenty of options at $40. I've bought some of the cheaper batteries and found that they don't last very long. The following are some choices on Amazon and Rocky Mountain but there are plenty more.
So I'm asking you -- what are the specs I should be looking for to get a good battery at a good price.
Thanks so much.
Weize YTX14AH-BS High Performance - Maintenance Free-Sealed AGM ATV Battery Rechargeable Yuasa YTX14AH Motorcycle
Mighty Max Battery YTX14AH 12V 12AH Battery for Polaris 500 Sportsman HO '96-'13 Brand Product
YTX12-BS iGel Battery - High Performance, Maintenance Free, Sealed Motorcycle Battery
YUASA Standard Battery with Acid YB14AA2
   / Batteries -- what is the dif? #2
A sealed batt. cost more, but it won't leak all over if the ATV gets turned over.
I've found YUASA batts to be expensive, but of good quality.
SR
   / Batteries -- what is the dif? #3
SR
I second YUASA sealed also called AGM (absorbed glass mat) batteries. There is no chance of leaking plus the battery is usually located in a spot where you have to remove it just to check the acid level. I have had nothing but good luck with the YUASA AGM batteries. I know you will think I am crazy but I have a 18 year old battery that still starts my 1981 Honda goldwing. Spend a little now you will save in the long run I have bought cheaper batteries and only got a year or two out of them one was a sealed AGM by the name of Big Max only lasted 2 years.
Is there a standard code to their names -- similar to tire size. All the options in the ads make no sense to me.
For example, in the following list, does the number [12, 14, 30] refer to power?
What does the BS, LA, AH mean?
BTX14-BS
BTX30LA
YTX14AH-BS
YTX12-BS
YB14AA2
   / Batteries -- what is the dif? #5
   / Batteries -- what is the dif? #6
A little off topic but do you keep them on battery tenders when not regularly using? I have found this really helps with my smaller batteries for my tractor, riding mower, generator, etc.
   / Batteries -- what is the dif? #7
I've have the batteries on my ATV, motorcycle & tractor on battery tenders. They will normally last 10 -14 years. At around 12 years, I get nervous and replace a battery. With my luck - an older battery will die on the coldest day in the winter.
No. My garage doesn't have electricity. I know there are solar trickle chargers but I don't have much faith in them.
   / Batteries -- what is the dif? #9
I have good luck with solar chargers on my gate opener battery. I would highly recommend them but get one that produces at least 14 watts of power to trickle charge. That would be a little over 1 amp of charge power which is good for continuously charging without burning up the battery.
   / Batteries -- what is the dif? #10
I found that when my ATV sat for a couple weeks, the battery would be weak. Usually this wasn't noticeable when ridden regularly. But after buying 2 batteries in a couple years when the battery would sit for a month and be down to 9-10 volts I did some testing and found my ATV was discharging at about 30milliamps when ATV was turned off.
I believe its through a solid state starter relay (or some diodes)....
Once a battery's voltage gets to low for an extended time, I think it dies and doesn't come back (without serious desulphurization),
Sure a trickle charger could constantly feed the parasitic load draining the battery, but putting a switch on the negative battery cable cuts the parasitic load to zero, and saves battery.
MINI EXCAVATOR BUCKET 24 (A55745)
MINI EXCAVATOR...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A57024)
2023 NEW HOLLAND...
2003 Pierce Spartan Pumper Fire Truck (A55852)
2003 Pierce...
2025 Swict 84in Bucket Skid Steer Attachment (A55851)
2025 Swict 84in...
Miller Spectrum 500 DC Plasma Cutting System (A55851)
Miller Spectrum...
2004 AGCO Gleaner 3000 Corn Header (A57024)
2004 AGCO Gleaner...
