Batteries -- what is the dif?
   / Batteries -- what is the dif? #11
Interesting link. Thx for posting.
I buy a lot of batteries for ATVs, M/Cs, etc. I used to think that the number in the code (e.g. 14 in BTX14-BS) was the Amp-hour rating. Until I found a few exceptions.
I buy all my smaller batteries (smaller than car-sized units) from eBay dealers, and they run $25-50 with shipping. Some are AGM, some come with sealed acid packs you add yourself, and some come dry w/o acid. With any lead-acid battery, you don't want to fully discharge them and leave them in that state. So older batteries that have been on the shelf for a long time, AGM or not, are not good. I like the dry ones for that reason, and esp when you can get them without the acid packs. I buy acid in gallons from the local autoparts store. I have had some defective batteries, but the seller always has sent a new one right away, and lets me recycle the old one. I have bought as many as 10 or so in one year.
I like the good battery maintainer-chargers, like the green ones from Battery Tender. The cheapos from HF are not so good. I have had one of the latter overheat and die, and one that overcharged a car battery.
Best lead acid battery brand I have ever owned (car or m/c) is Panasonic.
Finally, if you have a phantom load that is draining your battery (ATV, SxS, M/C), that is usually the regulator/rectifier, which is always connected to the battery. If you have a newer machine, there may be some electronics (other than the reg/rect) that can also drain the battery. My new ATV with FI does not have any phantom loads (measured with ammeter at battery).
   / Batteries -- what is the dif? #12
Has anyone heard of or tried a battery desulfator? My boss gave me a trickle charger/desulfator a while back I am just now trying it on my motorcycle batteries. It is supposed to desulfate or clean the plates of the battery by sending small pulses of electricity through the plates. Claims to extend battery life up to four times. I charged my 18 year old battery let it sit for a few tays, tested it with my voltmeter which read 12.45 volts. I put the charger/desulfator on it I am leaving it on for a month then will test it and put it in the bike and see if I notice any differance. This is the one he gave me. What do you think is it legit or snake oil? This is the one I have.
BatteryMINDer 1510: 12 Volt-1.5 Amp Battery Charger, Battery Maintainer, and Battery Desulfator – Designed for Cars, Trucks, Motorcycles, ATV, Boats, RV
   / Batteries -- what is the dif? #13
BatteryMINDer 1510: 12 Volt-1.5 Amp Battery Charger, Battery Maintainer, and Battery Desulfator Designed for Cars, Trucks, Motorcycles, ATV, Boats, RV
I have 4 they work...
I read through the article and basically found that the numbers and letters don't mean much -- mostly manufacturer's identification. I also get the impression that the one number that matters is the cold cranking amps -- although two batteries could have the same rating but be of significantly different quality. So other than experience, is there something that gives an indication of longevity.
   / Batteries -- what is the dif? #16
Some say, heavier batts last longer... For me, by far the longest lasting batteries have said Interstate on them, but I don't buy light duty batts., I only buy HD batteries, group 31 Interstate batts have easily been the best batts I've bought..
SR
   / Batteries -- what is the dif? #17
SR
In simple terms, a battery with the highest cold cranking amp rating (CCA) is the best.
Interstate batteries are the "best"....because a big part of Interstate battery costs go to advertising!
Contrary to popular opinion, Interstate does not manufacture batteries.
Interstate is simply a marketing company.
Interstate batteries are manufactured by Brookfield Business Partners, and/or Exide.
There have been only 3 MAJOR battery manufacturers in the USA.
East Penn, Exide, and formerly Johnson Controls.
Brookfield Business Partners is now apparently what was formerly the battery division of Johnson Controls.
   / Batteries -- what is the dif? #18
NOT at my place that isn't the reason, here Interstate batts have been best, because they have easily lasted the longest!
I don't give a dam what the brand of batts I buy, I buy accordantly to how long they last, period!
I also don't care who makes them, I've bought Exide from a parts house and they just didn't last as long, in fact, not half as long, although the last one got replaced under warr., and the replacement is still in that tractor.
The Walmart batts I've bought were really bad, never got one to last even two years, one was weak from the first month I bought it, they replaced that one!
Later this spring I'm going to buy another group 31 Interstate, maybe that one will be junk ?, I'll report how good it is, either way...
SR
   / Batteries -- what is the dif? #19
Good to hear, I like the fact that the unit I have both maintains the battery and desulfates it. It will constantly be moved to whichever battery has sat the longest I don't have to buy batteries very often but when I do I never like it.
   / Batteries -- what is the dif? #20
SR
Different strokes for different folks.
I previously bought only Interstate.
Interstate stiffed me on a warranty claim while traveling in Canada.
Two Canadian dealers told me they were dropping Interstate because they had warranty problems.
No more Interstate for me ....EVER!
I have had great luck with the Walmart Everstart Maxx, and they cost less than an inflated price Interstate.
I keep a Battery Minder or Battery Tender on everything that is expected to sit for more than a month.
Olathe 172 Wood Chipper (A55272)
Olathe 172 Wood...
2016 CATERPILLAR 236D SKID STEER (A52709)
2016 CATERPILLAR...
New/Unused Quick Attach Bale Spear (A57454)
New/Unused Quick...
2016 Ram 4500 Wrecker/Snatch Truck, VIN # 3C7WRKAL4GG243467 (A57453)
2016 Ram 4500...
(15) UNUSED SDLANCH 94" X 42" HEAVY DUTY FLOOR (A58376)
(15) UNUSED...
Gehl 4640 Turbo (A57148)
Gehl 4640 Turbo...
