Gordon Gould
Super Member
- Joined
- Apr 1, 2007
- Messages
- 6,806
- Location
- NorthEastern, VT
- Tractor
- Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
The winch I just picked up from harbor frieght draws 37.5 amps. My ford 4500 generator puts out 22 amps.
My marine battery is rated at 875 marine cranking amps at 125 amp hrs.
What does all this mean?
How well will the generator keep the battery charged to run the winch and how will the battery do if I just run the winch off the battery and not connect it to the tlb?
To me it looks like you could run the winch for about 8 hrs if the generator can take running full load alot of the time.
The 125 amp hrs means you can draw 12.5 amps for ten hrs. Or 25 amps for 5hrs. ( Amps X Hrs = 125 Amp-Hrs ). The Marine cranking amps is the most currant the battery will supply for a short time and does not matter in your case.
So, if the generator supplies 22 Amps and the winch is drawing 37.5 Amps the battery needs to supply 15.5 Amps. 15.5A X 8 Hrs = 124 Amp Hrs. In real life things change. But I think it shows that it would at least be a reasonable set up. The generator being the weak point. You wont always be drawing 37.5 Amps unless the winch is really working all the time. And the battery wont always give you 125 Amp-Hrs unless it is perfectly charged, new, and around 70*F. And of course the battery will be recharging some during the time the winch is not running. Hope this helps.
gg
