Basic small engine problem - What fixed it?
   / Basic small engine problem - What fixed it? #1
stuckmotor
Super Member
Lower Up State S.C.
AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs
If you guys want to play, we'll see who answers the basic small engine question first.
Walk behind wouldn't start first time this spring. It had been under a tarp on a lift table since last run..
Pulled cord and got only one tiny pop
Put chainsaw mix of gas and oil into carb, got nothing
Squirted starting fluid into carb, got nothing
Put spark tester between wire and plug, got spark
The problem wasn't water in the gas. When I corrected it the mower started on the first pull
Why what made it start?
   / Basic small engine problem - What fixed it? #2
Blocked air intake on carb/air filter?
   / Basic small engine problem - What fixed it? #4
mud dauber?
has to be fuel related, you need spark, compression and fuel. you presumably have compression, you confirmed spark so something is preventing fuel to go in
final answer!!
   / Basic small engine problem - What fixed it? #5
Since it ran last and probably had poor quality fuel still in it, I'd say a dump and fill with new gas and possibly some new fuel lines from the Ethanol/gas deterioration of them.
mud dauber?
final answer!!
It was easier than that.
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
John Deere 853 20ft Corn Head (A56436)
John Deere 853...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
