Basic firewood rack.
/ Basic firewood rack. #21
Here is my version.
/ Basic firewood rack. #22
I use these for my drying areas as well as under the deck for my winter storage. 6 landscape timbers, 5 cinder blocks, no nails or screws and can put them together in about 2 minutes. Plus when i empty a rack i can move it all out of the way and stack the blocks up. They keep the wood off the ground, stack out about 16'long and i go about 4'high.
This is about the slickest and simplest way to store firewood I have ever seen!
CT
/ Basic firewood rack. #23
I'm wondering if one side could be notched or otherwise have a section or part or the side removed for access?
The openings all around the tote allow you to reach the wood to raise it up over the top or just pull it through the sides.
/ Basic firewood rack. #26
I do like them better than using t-posts, or cribbing the ends and they take down and set up nice and easy. And they can easily be made into 8' racks instead. The only downfall is moving from the drying area to the winter use/storage area. But i wouldn't want to try to move a whole pallet with my little kioti anyhow. So i use the trailer and just have to re stack. Another nice thing is the timbers are about the same cost as treated 2x4's in this area and the box stores usually put them on sale every spring. Lowes here just had them at 1.87 a piece so i stocked up.
This is them in use in one of the drying areas.
Getting good at this. Built two mor 10'ers. Only change is I made the feet are 24" instead of 18" and I'm using stainless steel #10 construction screws.
Hitachi EX 270 LC, Cab, 32" Track Pads, Grapple (A62679)
Hitachi EX 270 LC...
2016 Nissan Sentra Sedan (A61574)
2016 Nissan Sentra...
Case Axial-Flow Combine Wheels NO RESERVE (A63118)
Case Axial-Flow...
2005 Sterling Acterra Tender Truck (A63688)
2005 Sterling...
2017 Nissan Pathfinder SUV (A61574)
2017 Nissan...
Kubota L3901HST
Kubota L3901HST
