Barrery light?
/ Barrery light? #11
Well everything in his Avatar, Profile and Signature points toward the latter. But I see where you're coming from.
You are right, I now see the 200CX loader which confirms a compact.
/ Barrery light?
This is the compact 2520 not the larger unit.
I pulled off the dash yesterday and traced the wiring ....however.... I did not find any issues. I hope to pull the alternator today for testing per a couple recommendations.
Will keep everyone updated as I proceed.
Thanks again for all the suggestions!!
/ Barrery light?
So ... I pulled the alternator to get bench tested and because all the parts stores (autozone, o'rylies, Napa, Baxter) could not cross reference they would not test. I tried the 2 local Deere dealership but it must be on the tractor to test. I suppose... I will try to find an alternator repairs shop to see if they can test.
/ Barrery light? #14
I'll bet smoked the diodes in the alternator
2019 ALLMAND LIGHT PLANT (A60736)
2019 ALLMAND LIGHT...
20in Digging Tooth Bucket Excavator Attachment (A60352)
20in Digging Tooth...
(APPROX. 640BF) 1X6X6-16 WHITE PINE TONGUE & GROOV (A52706)
(APPROX. 640BF)...
Patterson water pump (A59230)
Patterson water...
2022 FORD F-250 STX CREW CAB TRUCK (A59823)
2022 FORD F-250...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
