Barn to workshop
/ Barn to workshop
I am taking out the slab as it is cracked and heaving and not salvageable......
/ Barn to workshop
Heres why the slab was messed up...
/ Barn to workshop
The slab was pitched up in the middle and sloping away from the trees. If you had any doubt what tree roots can do to concrete this should put them to rest....
/ Barn to workshop
Whoever layed this slab did nothing but set up some forms and pour. No base, No rebar, basically just broke apart as I forked it. This piece was pretty heavy and awkward as the weight was so far out.
/ Barn to workshop
This weight was so far out on this piece that it pulled the back wheels just off the ground and held them.
/ Barn to workshop
I experimented a little with this one, as I drove the thing would teeter and when the rear wheels touched it would give some directional control /forums/images/graemlins/shocked.gif In the end I let the front part of the slab back down and adjusted the tilt so it would take just enough weight off the front to regain the steering. I then drug it in reverse over to the bone yard.......
/ Barn to workshop
Tractor moving the small stuff /forums/images/graemlins/grin.gif
/ Barn to workshop
Slab is gone, took about 3 hours with a couple of breaks /forums/images/graemlins/smirk.gif Those 3 roots did all the damage and now they have to go too......
/ Barn to workshop
Now I gotta dig these puppies out /forums/images/graemlins/confused.gif
/ Barn to workshop
A pic to guage the size of these things.....
/ Barn to workshop
I jumped on the trusty RootFork and dug in /forums/images/graemlins/grin.gif If you notice the rear wheels are light and the front wheels are under a very large load.....
/ Barn to workshop
I don't need no stinkin backhoe /forums/images/graemlins/cool.gif the roots give way with a bang, but once broke you can pull them by hand. Very brittle stuff.
/ Barn to workshop
Roots out and Moved about a yard of soil, you can see where the old level was on the stumps.....
/ Barn to workshop
Another shot, If you look in the lower left hand corner of the pic you can see the forks. I bent one last week trying to pry that wedge out of the stump in the pic /forums/images/graemlins/shocked.gif
/ Barn to workshop
This is a shot of both inside and out of the North stump. If you look on the inside you can see the how far the roots go in to the barnshop.
/ Barn to workshop
This is the South stump, fully a third of the tree was inside the wall. Someone in the past had cut the base beam out from about mid point on the wall. The tree at its widest point outside to inside was 63" across. That's Atticus in the background guarding my jobsite /forums/images/graemlins/cool.gif Still alot of work to get done but knocked a good chunk out today /forums/images/graemlins/grin.gif
/ Barn to workshop
Here is the closing pic for today, slab gone roots gone outside now if I can get ahold of that stump grinder /forums/images/graemlins/mad.gif
/ Barn to workshop #198
Are you accounting for the fact that the wood from the stumps left in the ground (after grinding) will eventually decay and leave a ground void? Just wondering if some of the barn foundation is sitting over top of the roots that will not be there in 10 years.
Great pics, and good progress with the big trees. That is a big project, but looks like you have the right equipment for it. /forums/images/graemlins/wink.gif
Am curious what you meant when you said you were breaking the wedge loose (when you bent a fork). Didn't quite get the mental picture of what that was.
/ Barn to workshop #199
</font><font color="blue" class="small">( Are you accounting for the fact that the wood from the stumps left in the ground (after grinding) will eventually decay and leave a ground void? Just wondering if some of the barn foundation is sitting over top of the roots that will not be there in 10 years. )</font>
Larry,
I was thinking the same thing when you mentioned pouring concrete. Depending on what you'll be using the space for will dictate how much strength you'll need.
It might be worth going up a size in rebar and halving the size of your grid. Something like half inch sticks on 12 inch centers should allow you to bridge the area as it decays over the years.
The other option might be to plan on the decay and cracking of the slab and pour it in sections that could be removed and re-poured when the time comes.
Glad to see those trees gone!!! Nice job.
Eddie
/ Barn to workshop
beenthere, I have been thinking about it just was'nt sure what I was going to do about it. Eddie has posted a fix which sounds like the way to go since digging all the roots up is not an option.
ahh the wedge, when my tree guy was still here we were whittling down the south stump. he had made a vertical cut and a horizontal cut trying to knock it down a piece at a time. I drove the fork up to pry the piece off, obviously it was still strongly attached /forums/images/graemlins/shocked.gif The problem with the stumps is that over the years as they have grown they have picked up rocks and dirt in the cavities, we trashed 2 chains getting it where it is now /forums/images/graemlins/mad.gif Thanks for the kind words......
New Quick Attach Hay Spear (A65563)
New Quick Attach...
2004 53ft. Kingman Dry Van Trailer (A61573)
2004 53ft. Kingman...
2006 MACK CHN613 DAYCAB (A67714)
2006 MACK CHN613...
2020 CATERPILLAR 259D3 SKID STEER (A65056)
2020 CATERPILLAR...
2022 CATERPILLAR 313 EXCAVATOR (A65056)
2022 CATERPILLAR...
1 PALLET OF JACK & IMPACT GUNS (A66091)
1 PALLET OF JACK &...
