Barn siding help
/ Barn siding help #1
Tractor_Jim_CT
Connecticut
BX23
Hi everyone
I have a barn constructed of cedar. I recently finished power washing the inside and it came out great. But my problen is with the outside. The barn was built in the mid-80s and the outside wood has turned black and a rust brown. The other issue I have is the board-and-batten siding look. I want to keep the board but I want to remove the battened part which sticks out and put a layer of tongue-groove 8 inch or 10 inch board over the current cedar board after removing the 1 inch battened board. Then paint or stain barn red the new board
Should I put a covering over the cedar layer before putting the new siding on? /forums/images/graemlins/confused.gif
Should I put the new cedar tongue and groove siding over cedar or would you use pine instead? /forums/images/graemlins/confused.gif
The board is verticle
Thanks in advance
/ Barn siding help #2
Jim, you can certainly put the wood on wood if you like. Which ever wood you prefer is fine also. The thing to watch for IMO would be the seams where the batten had been. The batten acted as a barrier to the weather. Be sure the T&G misses, even if it's a little, the old batten seams. It's not a real big deal because of the nature of T&G and how it goes together. However you will get some expansion and contraction and some of the seams will loosen over time. I'm sure you see where I'm going. Outside of that, have at it and have fun.
/ Barn siding help #3
If I understand this, you have a board and batton ceder exterior barn. You do not like the look of the battons and the way the cedar has weathered over the years. You want to pain the whole thing red when your'd done.
Since your painting it anyway, why go with spending all the time and MONEY on tounge and groove boards? Cutting and fitting alone will take forever, not to mention what that stuff sells for. They your going to cover it up with paint!!
Remove the battons and cover the walls in a material that appeals to you that is designed to be used as siding. There are all sorts of 4x8 sheets to choose from plus vinyl and metal.
Personally, I'm liking the James Hardi panals. I put my scraps in my burn pile and they didn't even change color. It hold paint very well, its bug proof and it will never rot.
Good luck,
Eddie
/ Barn siding help #4
You will need a barrier between the original siding and the new boards to help prevent rot. Something like Tyvek house wrap, rosin paper or felt paper would do.
/ Barn siding help #5
I bought a cedar clad house in July. It hadn't been treated and the condition of the siding was awful, black, stained and to be honest I thought the siding was done. Before I overclad it, I thought I'd at least see if cleaning it up would work so tackled it with a powerwash. It still looked bad so I sprayed it with a dilute solution of TSP and scrubbed it with a stiff, short haired broom then powerwashed it again. While it's not perfect, the results are way better than I expected and good enough for me to live with until I relocate the house next year and carry out a comprehesive remodel. The attached photograph shows the difference. I'd cleaned as far as I could reach without scaffolding in this shot and the original siding condition can be seen above the window. The whole house was like that. I've since cleaned about six feet higher using the FEL as a working platform but will need scaffolding to get into the high parts of the gables.
Might be worth carrying out a sample on your building this way. If it works, it'll save you a deal of money in overcladding. If not, then at least you'll be absolutely sure painting or overcladding is the only real answer.
/ Barn siding help #6
Oops. Here's the photograph . . .
/ Barn siding help #7
Sounds expensive, to say the least, to add siding over the top.
Have you tried cleaning the old siding as "inveresk" suggested? TSP or just a spray of bleach/water solution will do wonders to get rid of the mold that causes the dark black and gray look that you see.
Some people like this black to gray look and also don't like putting on any kind of finish. When wood is left to the elements with no treatment, it will turn dark because of the mold.
/ Barn siding help #8
ID wrap it in typar first,no water will get through it,and yet it can still breath.This is what us rednecks use for siding up here in MAINE /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
ALAN
/ Barn siding help
Thanks as always to the TBN group for your thoughts and ideas and appreciate the help.
Basically I don't like the board-and-batten look. I might try cleaning a section on the outside and test red barn color stain on the section after it dries.
I've learned I can put a outer layer of T&G boards, but should wrap the outer layer 1st. Probably would clean before wrapping. I should line up the T&G so it doesn't go over the battened board that was removed.
I am remodeling the garage/barn to look more like a barn. It has two front garage type doors. My plan is to remove one of the doors by closing in the wall. The other door will be changed to a sliding right to left barn door, to be purchased from Circle B. More windows will be added and the wood question of this post is to give the outer barn a more vertical, smooth barn look. Exterior stairs will be removed from the back of the barn and stairs will be added to the inside of the barn to get to the 2nd level. I'd also like to add a walkout deck on the rear 2nd floor, which overlooks a river.
The wood question is to dress up the barns look. Even though it's expensive, it will add to the appearance and probably insulate the barn a little better with the 2nd layer. The barn has a wood stove and will probably have to replace it.
Does anyone know where to buy exterior barn cedar board T&G that will sell to a barn/homeowner and ship?
Thanks again
/ Barn siding help #10
What size 'board' are you looking for, what cedar do you want, and how many square feet are you talking about?
Do you plan to nail the new boards all the way into the nailers that are under the boards now on the barn? or just nail it to the boards?
/ Barn siding help
Tongue and groove cedar 8 to 10 inch wide planks ...
what do you have on your end
Thanks
/ Barn siding help #12
Don't know if it's available in your neck of the woods but the Buy, Sell & Trade magazine is full of ad's in the 'construction materials' section for cedar siding, including board and batten.
/ Barn siding help #14
Not to my knoweldge. A search only brings up BuySell.com which is different but which might bring you some luck. Buy Sell and Trade is one of those free-to-advertise mags. which cost a couple of bucks to buy. You've probably got something similar wherever you are. Here, it's a great source of used construction materials, tools and ag. equipment.
/ Barn siding help #15
I just finished an addition to my barn and changed the siding to Spruce Log T&G and stained it with Sikins Natural Oak. Came Out nice. I put OSB over the studs and then Tyvek vapor barrier. You could use Tyvek over the Cedar T&G and then your new finish boards.
See attached two pictures of the finished look.
/ Barn siding help #16
One more picture.
This siding really goes on nice and give a rustic log look. Trims out nice in 2x4.
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2006 GMC W3500 Truck, VIN # J8DB4B16867021673 (A65563)
2006 GMC W3500...
2015 JET 42' ALUMINUM HOPPER BOTTOM TRL (A64277)
2015 JET 42'...
10in Bucket w/ Teeth Excavator Attachment (A64194)
10in Bucket w/...
NEW Landhonor 20,000lb Electric Winch (A62679)
NEW Landhonor...
Pallet of Two Pivot Wheels & Tires (A62177)
Pallet of Two...
