Barn Post Question
   / Barn Post Question #1
Believer
What are typical procedures for the bottom of the post in buried post barn? I mean what goes into the post hole besides the post? Size of the barn will be 40x60x14. Thanks.
   / Barn Post Question #2
I have 36" holes and about 6"8" of limestone in the bottom. Some use concrete, rubber.... others dirt....
   / Barn Post Question #3
Depends on what the frost line is. Up here it's 48" I usually go about 60" and put 12" of clean gravel in before I set the post.
   / Barn Post Question #5
I set my posts for pole barns and decks both in concrete. I make the bottom of the hole wider than the top to resist upheave and taper the top ot the concrete away from the post so it doesnt Pool around the post.
With my 8" PHD and a 4x4, this is usually two bags. On my pole barn, using anywhere between 8-10" utility poles and a 12" digger, it was still about two bags per hole.
   / Barn Post Question #6
When Cleary built our 42' x 72' x 12' barn, they put a concrete "cookie" in the bottom of the holes, and then attached two "wind blocks" to the bottom of each post - the wind blocks being just a piece of nailed on 2" x 6" PT to prevent uplift. Holes were then backfilled with dirt.
   / Barn Post Question #7
Concrete footer under the post, your choice of material to fill around the posts.
   / Barn Post Question #10
Concrete cookies and gravel, then crete it in. Or you could use sona tubes over deck blocks and make sure to cut the sona tube lower than grade and fill with concrete to grade so that the concrete is larger at the top for frost heaving.
Deer Gates (A53424)
Deer Gates (A53424)
2008 Ford F-550 4x4 Dump Truck with Lift Gate (A53422)
2008 Ford F-550...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
2018 VOLVO SD75B SMOOTH DRUM ROLLER (A51406)
2018 VOLVO SD75B...
2023 MAXEY G8X 26FT TILT BED GOOSENECK TRAILER (A54607)
2023 MAXEY G8X...
2001 CHEVEROLET C6500 3 CAR ROLL BACK (A54607)
2001 CHEVEROLET...
