Barn Dutch Door Question
   / Barn Dutch Door Question #1
Lykele
Kentucky
I wonder if someone might be good enough to answer a question as related to building a dutch door for my barn stall.
I did find some step by step instruction with a few images so I'll probably follow that method. How to Build Barn Doors - Free Woodworking Plans - Make Barn Doors
However in these instruction, when connecting the 2x6 pieces that make up the frame, it is suggested to "toenail" a couple of 3" screws to hold it together. These 2x6 corners are at a right angle to each other not cut at a 45 degree angle.
I just took a few scrap pieces of 2x6 and tried this method, but it doesn't seem like those 3" screws go very deep. Then if you have a larger frame I worry about the strength. Unless tying in the T1-11 helps.
Could anyone suggest to me methods of connecting this frame together? Would using smaller wood 2x4 be an option? This is a 20 year old barn some mainly we're going for a look as well as a function door.
Thanks for any advice you can pass along.
Jim
   / Barn Dutch Door Question #2
Jim,
A few alternatives:
1) use longer screws,
2) reinforce the butt-joints with strap ties, or
3) use lap joints rather than butt joints.
Steve
   / Barn Dutch Door Question #3
Agree with Steve, on these types of doors I've used Lap Joints in the corners, and diagonal bracing inside the frame. pretty sturdy once you get the boards on.
   / Barn Dutch Door Question #4
Consider assembling the frame using biscuit joints and glue. I'd also introduce a rebated joint rather than a bevel at the meeting stile of the upper and lower leafs.
2002 International 4300 Cab and Chassis Truck, VIN # 1HTMMAAP02H548742 (A51572)
2002 International...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
2011 KOMATSU PC160LC-8 (A52472)
2011 KOMATSU...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
New/Unused 30ft x 65ft x 15ft Storage Shelter (A51573)
New/Unused 30ft x...
