Barn door design
/ Barn door design #1
blaze
Central Florida
Kubota B6100E with dreams of a B7500
I am looking for a proven design for hinged barn doors. Each one will be 8' X 6'. I know that most tend to sag over the years. A sliding door is not an option for me. Any help would be appreciated.
Mike
/ Barn door design #2
Mike,
For a door that big I have two suggestions:
1. Use at least 4 hinges
2. Put a diagonal brace in from the bottom inside of the door to the top outside. Most people put the diagonal the opposite way, and wood does not work well in tension like that. Better (if using a wood diagonal brace) that it's in compression.
Another way to do it is to put a steel cable from the top inside to the bottom outside (this is in tension), and put a turnbuckle in it. That way if/when the door does start to sag, you just tighten up on the turnbuckle.
The GlueGuy
/ Barn door design #3
Mike:
You might try a chevron-style door. I think they were most popular in the 1920's (but am not at all sure on that). Anyway - start with an inside layer of either 1x lumber or 3/4" external grade plywood and the layer v-groove pine on the outside at a 40 degree angle or so. The other door should have the boards going on the opposite slope. You can also put some horzontal and vertical boards to frame the effect - depending how fancy you want to get. 'Hope this description makes sense.
The advantage of the two layered approach is that it reinforces in multiple directions. My workshop doors are just vertical T&G boards on a couple of planks and so they sag toward the middle - the chevron design avoids that. Another thing - dry fit the whole thing on the ground and then dissasemble and prime every surface - your door will last MUCH longer (course ya' gotta paint it too - after it's up).
Good Luck!
Andy in NH
/ Barn door design
Thanks guys, both great ideas. I'm a couple of weeks away from that project as I am in the process of siding the barn. I will let you know how the doors turned out.
Mike
/ Barn door design #5
Glue, Glue, Glue,
I recomend you glue the coss and diagonals with a polyurathane water proof glue. The doors will not sag if they are well glued to eliminate any changes in shape. I have used this on several exterior barn doors with great results. The glue can be a little expensive but well worth the money.
-Roger
/ Barn door design #6
Mike,
I don't know your situation but could you use a rollup door? They can usually be put anywhere. I would think with an 8 foot by 6 foot door no matter how well you build it you are going to have problems. Another idea is instead of making an 8x6 door make two 8x3 doors and fasten them in the middle.
/ Barn door design #8
Doc,
I may be miss-reading the original post (wouldn't be the first time /w3tcompact/icons/crazy.gif), but my read on it is that he was talking about two 8x6 doors already.
The GlueGuy
/ Barn door design
Yes, I need two 8X6 doors to handle a 12' opening. I don't really want a roll-up due to expense and loss of ceiling height when in the open position. Door will stay open most of the time here in central Florida, except of course when in dips into the 40's. :)
I assume I will need gussets at each corner no matter what design I go with, correct?
Just for kicks, does anyone know how much a roll-up door for that opening would cost?
/ Barn door design #10
Blaze,
I just priced new 7x6 roll up doors for my stalls on my new barn. $190 a piece.
/ Barn door design #11
<font color=blue>I don't really want a roll-up due to expense and loss of ceiling height when in the open position. </font color=blue>
When I worked in an a large industrial building they had metal roll-up doors that actually rolled up into a roll at the top, so it ate up very little overhead space. I'm guessing these cost a pretty buck, but it would be interesting to check into. Here's an example of what I'm talking about.
/ Barn door design #12
Harv,
I've seen doors like this where the roll in on the outside so as to take up no room on the inside. There is a cover for the roll to protect it. Or you could build a small roof to hide it.
/ Barn door design #13
<font color=blue>metal roll-up doors that actually rolled up into a roll at the top, so it ate up very little overhead space. I'm guessing these cost a pretty buck</font color=blue>
Hmm, that's what my shop door is and I figured it was probably cheaper than the other types. Of course, since it was there when I bought the place, I've never priced them. I'll have to admit I do like it better than the others.
Bird
/ Barn door design #14
I think they're cheaper and they you don't lose any headspace to speak of with them. On my new barn to build sliding doors for the stalls cost $280 by the time you figure the cost of the door, track, and sliders, compared to $190 for the rollup. On the bigger doors, 14x12 price was $322. When I ordered my barn they said rollups were the cheapest doors to go with by about 30%.
/ Barn door design #15
Mike:
At my web page (near the bottom) http://members.aol.com/wvbills/Construction.htm you will find a picture of the barn doors I built last year for my pole barn.
They are 6' w X 12' h. They're made of T1-11 exterior plywood on a 2 x 4 frame (inside). There is a 1 X 3 diagonal brace across the inside from the top-hinge side to the bottom. The bracing on the outside is 1 X 4 peices. I put three 8" T hinges on each door. They've been up a year and have not shown any sagging yet.
/ Barn door design
Great looking barn and doors! Thanks for sharing that with me. These guys have me leaning towards roll-up doors but yours proves that a hinged door is a viable alternative.
Will keep you posted,
Mike
2018 KAUFMAN GOOSENECK TRAILER (A63290)
2018 KAUFMAN...
Ritchie Bestway Pull-Type Sprayer (A66285)
Ritchie Bestway...
2025 Stump Grinder Hydraulic Mini Excavator Attachment (A61572)
2025 Stump Grinder...
2017 JOHN DEERE 317G SKID STEER (A65053)
2017 JOHN DEERE...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
New/Unused 3 Point Hitch with Ball/Flat Hitch (A65583)
New/Unused 3 Point...
