Hay Dude
Super Star Member
- Joined
- Aug 28, 2012
- Messages
- 18,758
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
I am certified on a number of automotive manufacturers paint systems. NONE of them have, use, require or recommend a rust converter in their best practices. That should tell you something.
If you are not going to properly clean the metal for paint, it's a waste of time painting it. Rust converter is a gimmick for homeowners to use when they can't, or won't properly prepare the metal. If you remove the rust, there is nothing to convert.
Preparing that frame for paint while it's on the truck will be all but impossible.
The rust needs oxygen to form. If you cover the metal with anything that blocks the air and water from it, it's going to prevent corrosion.
I suggest you scrape and wire wheel it thoroughly, them apply a coat of a professional quality undercoating: Rusfree ruberized undercoating, which you can brush, or spray on, https://a.co/d/7hjbILp That will actually do more to protect it than anything you can do yourself. While it's a dirty job, it's very cost effective. It does dry enough to touch it without transfer, but will never crack, or flake off if the surface is clean when applied.
Just read a bunch of actual user testimony and write ups on rusfree. Looks promising.
A few recommended rust converter first, then apply rusfree.
I am kind of feeling overwhelmed with different tactics and products to do this.
Would the rusfree look like black paint enough when done to look good? If the frame is black and preserved, mission accomplished. Truck isnt a show piece. Longevity is the goal.
