Bar vs Turf
/ Bar vs Turf #1
JWKnopp
South Jersey
BX23
Hi all, thanks for being here.
Very valuable in deciding on the Kubota.
We are going to purchase a BX23 and a 60" Landspride RFM.
Have 10 acres ( 3 yard & weeds/7 woods plus 200" asphalt driveway.
One use will be snow removal. Which tire type would be the best versatile, yet effective choice, Bar or Turf. /forums/images/graemlins/confused.gif
/ Bar vs Turf #2
Welcome to the forum. This same discussion is currently running in both Kubota forums. Click on these links to read the discussions:
Thread 1
Thread 2
You will be able to find lots of information already written in these threads. Enjoy TBN. It's a great place to learn.
/ Bar vs Turf #3
From my experience this past winter, I changed from turfs (w/ 50# bolt-on tire weights) to AGs (loaded w/ fluid). My traction increased greatly. No slippaged at all. Excellent sterring capability too, especially when I needed to use the FWD.
About 3 weeks ago, I installed a complete dry well system in my yard. In a "wet" area of the yard, I thought I was going to be stuck, but w/ the AG tires, I came out no problem. If the turfs were on, forget it, I would have had to get the P/U out of the garage! The downside to the bars is that I left a lot of ruts in the grass from the tires. Now that my spring digging projects are over, I have swapped over to the turfs. I really want to put on a set of R4 industrial tires to get the best of both worlds, but they are a little out of my price range. I hope this helps you out.
/ Bar vs Turf #4
I would point out here that blackmajicwoman has these bar tires liquid filled. The damage indicated to the turf would not normally occur with pneumatically filled bar tires.
/ Bar vs Turf #5
By all means the bar (R-4 industrial) are the best compromise in my opinion. I've had Ag's, (tore up the yard something awful and left ruts) and Turf, ( great on the yard but very poor traction even in wet grass let alone snow/mud). The R-4's do not rut hardly at all and almost no damage to grass unless making tight turns in FWD and great traction although I suspect they will load up easy in soft mud.
/ Bar vs Turf #6
</font><font color="blue" class="small">( From my experience this past winter, I changed from turfs (w/ 50# bolt-on tire weights) to AGs (loaded w/ fluid). My traction increased greatly. No slippaged at all. Excellent sterring capability too, especially when I needed to use the FWD.
About 3 weeks ago, I installed a complete dry well system in my yard. In a "wet" area of the yard, I thought I was going to be stuck, but w/ the AG tires, I came out no problem. If the turfs were on, forget it, I would have had to get the P/U out of the garage! The downside to the bars is that I left a lot of ruts in the grass from the tires. Now that my spring digging projects are over, I have swapped over to the turfs. <font color="brown"> I really want to put on a set of R4 industrial tires to get the best of both worlds. </font> )</font>
<font color="brown"> But they also offer the worst of both worlds.</font>
/ Bar vs Turf #7
</font><font color="blue" class="small">( By all means the bar (R-4 industrial) are the best compromise in my opinion. I've had Ag's, (tore up the yard something awful and left ruts) and Turf, ( great on the yard but very poor traction even in wet grass let alone snow/mud). The R-4's do not rut hardly at all and almost no damage to grass unless making tight turns in FWD and great traction although
<font color="purple"> I suspect they will load up easy in soft mud. </font> )</font>
<font color="brown"> R-4's plus mud equals Racing Slicks.</font>
2018 KEARNEY TRAILER 24 FT GOOSENECK TRI-AXLE (A63569)
2018 KEARNEY...
International MaxxForce 6-Cylinder Turbo Diesel Engine with Transmission (A59228)
International...
2019 John Deere 712C Cornhead (A63111)
2019 John Deere...
2020 Case TV370B Track Skid Steer (A64047)
2020 Case TV370B...
2003 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2003 Ford F-150...
2014 JAYCO JAYFEATHER TRAVEL TRAILER (A63569)
2014 JAYCO...
