Baptized My New EZ-Hitch Hooking up the Chipper
   / Baptized My New EZ-Hitch Hooking up the Chipper #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
I just received a cat 1 EZ-Hitch set from Carter and Sons and tried it out hooking up to the chipper I got from Ronald at Ranch Hand Supply. That one item has been the toughest for me to hook up by myself for some reason (probably due to uneven ground), so I thought it would be a good test. It didn't take even three minutes...
The chipper has worked out well. I added some 4x4's to the base to get a better angle with the PTO shaft & for better stability when not hooked up. I had to use some bar stock to extend the top link, but that works well.
Nick
   / Baptized My New EZ-Hitch Hooking up the Chipper #2
Nick
Hello Nick, I also added two 4x4 PT skids under my Wallenstein BX42 when I bought it a couple of years ago, a very nice inexpensive solution to what you also have found out.
My NH TC40 has extendable lower arm 3-PT adjusters so I haven't felt the need for a quick hitch but good luck with yours.
   / Baptized My New EZ-Hitch Hooking up the Chipper #3
Got more photos of the EZ-Hitch??? Just interested in seeing them. :thumbsup:
Got this one ...
Nick
   / Baptized My New EZ-Hitch Hooking up the Chipper #5
Thanks, is there much "rocking" back and forth? or are they pretty tight on there? I didn't like my Harbor Freight QH since it had some "play" when it's connected.
   / Baptized My New EZ-Hitch Hooking up the Chipper #6
I ordered a set of thoughs, and gave them away. I went back to the speeco
qh. good luck with them
david
   / Baptized My New EZ-Hitch Hooking up the Chipper #7
I got a set of those several years ago and have loved them. They make hard jobs easier for this old man.:thumbsup:
Not that I've noticed so far. A couple of plastic rings (small pipe slices) about the diameter of the swivel balls were provided for each arm to counter any side to side tilting. I only used one on each arm since that seemed adequate. Any front to rear tipping is pretty minimal as the opening is 2 5/8" tall and my lift arms are about 2 1/2" (if memory serves).
This really is the first time I've used them. I'll know more after hooking up & working with a few more items. I think any movement issue would have to be really noticeable for it to outweigh the greater ease of getting connected these look to provide. A big plus, from my point of view, is they were about $90 delivered (via priority mail) and very simple to install and use.
Nick
   / Baptized My New EZ-Hitch Hooking up the Chipper #9
Good deal, keep us posted how they do... :thumbsup: I have a friend I might get these for...
   / Baptized My New EZ-Hitch Hooking up the Chipper #10
I have Pats, and have worked quite well; but I like th simplicity of the lock mechanism of yours. I have had pats disconnect from me a few times....
Pats carry off the end, so the carry point is different. Have to think on this one..
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
2017 Ford Explorer AWD SUV (A50324)
2017 Ford Explorer...
2006 Ford F-150 Pickup Truck (A51692)
2006 Ford F-150...
Case International 585 Tractor (RUNS) (A50774)
Case International...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Post Hole Digger Auger (A50774)
Post Hole Digger...
