bang for the buck,, which machine
   / bang for the buck,, which machine #21
I personally Have a large B and I really love it. There is much to consider. Are your stalls going to be accessible with your tractor, Do you have a hight issue moving your tractor inside. Are you doing finish lawn cutting with it, Are you working in tight spaces in the woods or around buildings. The Ls are heavier than the Bs as well as larger. Now if I was only doing ground engagement I would Go with an L. If I was doing Lawn maintenance and working inside my barn or in close quarters then I would go with a B. I would also consider a Tach-all for the loader and a light duty grapple and rear remotes. See you can dump all your money into as big a tractor as you can buy or go with one you need and set it up for the future. Bang for the buck can mean a lot of things
2014 BMW 328i Sedan (A55758)
2014 BMW 328i...
2017 KENWORTH T680 SLEEPER TRUCK (A54313)
2017 KENWORTH T680...
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
2015 Ford F-250 Ext. Cab 4x4 Flatbed Truck (A53422)
2015 Ford F-250...
BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A55787)
BrushFox XHD-78HF...
1967 Ford F100 (A47477)
1967 Ford F100...
