Bandsaws and coldsaws
/ Bandsaws and coldsaws #11
With bandsaws it's all about the blade and having the right speed and feed rate. Bandsaw blades need to be broken in or they will wear fast and cut slower. If you have lots of cuts in the same material, you can stack the pieces in a bandsaw.
/ Bandsaws and coldsaws #12
My bandsaw blade blade sometimes hangs when I stack cuts horizontally and leave the saw unattended. I finally destroyed a motor that way.
/ Bandsaws and coldsaws #13
Do you repeat the same cut? If so some bandsaws will self feed and cut.
/ Bandsaws and coldsaws #14
Try a Kool Mist unit on the cold saw. Great lubrication for the blade with no liquid to deal with once the cut is done.
/ Bandsaws and coldsaws #15
Talking about cutting metal, I need something better than a reciprocating saw. I am thinking about a abrasive cut off saw since are cheaper, but I don't want to kill myself in the process.
/ Bandsaws and coldsaws #16
I worked production in the saw department for incentive pay one summer. No one wanted to stand and wait for the saw to cut. To get to that place, every sawyer had 2 saws running at the same time.
I found an ellis 1500 for $950. How do you guys think the 1500 compares to the 1600 and 1800?
2023 CATERPILLAR 304 EXCAVATOR (A62129)
2023 CATERPILLAR...
2023 Bobcat T66 R-Series (A60462)
2023 Bobcat T66...
2018 International WorkStar 7400 T/A Lely 4,500 Gallon Septic Wet Vacuum Truck (A61568)
2018 International...
ROSCO SPR-H CHIP SPREADER (A59823)
ROSCO SPR-H CHIP...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Kubota BX25D (A53317)
