Bandaid for Gasoline Spout?
   / Bandaid for Gasoline Spout? #1
TerryR
Boone, NC
JD 870
I have an ancient 1-Gal. metal gas can I use for mixed fuel for small engines. It has a handy flexible (rubber, plastic?) spout with a plug on the end and a nice big opening for mixing oil and fuel. No doubt no longer legal.
Trouble is some critter chewed a hole in the spout. I don't find anything as handy currently offered. It looks like it could be fixed with a tight wrap of tape. Is there any sort of tape that would withstand gasoline?
   / Bandaid for Gasoline Spout? #2
How about the self sealing silicon based tapes? According to their info it is chemical resistant.
Rust-Oleum® LeakSeal® Self-Fusing Silicone Tape is a self-fusing, silicone repair tape that conforms to any surface while providing a water-tight seal. LeakSeal Tape creates a chemical and moisture resistant barrier that fixes leaky pipes and hoses and covers frayed electrical wires. It is easy to remove, leaves no sticky residue and protects from corrosion.
   / Bandaid for Gasoline Spout? #3
Plain old electrical tape has made split gas spouts usable for me :D
   / Bandaid for Gasoline Spout? #4
I used self-vulcanising tape whilst in the Navy... a few wraps of that would fix your problem IMHO.
Thanks to all that responded. I tried the electrical tape since I had that on hand, and so far so good.
   / Bandaid for Gasoline Spout? #6
Gasoline melts the glue on electrical tape. It will probably work for awhile.
I understand why you want to use that old spout, I am pretty sick & tired of the safety spouts, I never spilled so much gas as with safety spouts. Plus it takes 10 times as long to fill, increasing the opportunity to spill. Often I get so tired holding a 5 gal can I have to put it down for a moment to change hand positions and I spill doing that.
You find an old can with a goos spout (or vent) KEEP it!
   / Bandaid for Gasoline Spout? #7
I am also mystified at the way spilling so much fuel is acceptable with the so called safety caps. Those old 5 gal gas cans with the 2 piece lids worked flawlessly for me and I honestly cant remember spilling any fuel with them except the very first time I ever used one when I was a little kid filling my grandfathers old push mower. With these safety spouts I spill fuel almost every time I am forced to use one.
I see some good spouts for sale online but they are not listed for fuel cans but rather things like water filling spouts but many will work on the fuel cans as well. Do a search of E-bay and you might be surprised what is out there
   / Bandaid for Gasoline Spout? #8
I think it has a lot more to do with lawsuits, and the industry that uses our judicial system for their profit. Gov't is forced to act and then takes the blame but someone already got the money. Then we're stuck with the new problems.
Good suggestion on the water spouts!
   / Bandaid for Gasoline Spout? #9
I have a spare one of those handy rubber spouts with the plug that I got somewhere and I am NOT letting go of it!!
The EZ Pour replacement spouts work good if you don't mind adding yet another $10 to your fuel can cost and can drill a separate hole for the manual vent.
- Jay
6"x8' Treated Post,  Approx. 28 Piece Bundle  (A52384)
6"x8' Treated...
2019 MACK P164T DAYCAB ROAD TRACTOR (A51406)
2019 MACK P164T...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51691)
2009 Hino 268...
1pallet of miscellaneous items (A53117)
1pallet of...
2018 E-Z Beever M12R Towable Brush Chipper (A51691)
2018 E-Z Beever...
2007 Freightliner M2 106 Medium Duty Pac-Man RL10 10 CuYd Refuse Garbage Truck (A51692)
2007 Freightliner...
