balls fell out , again !
/ balls fell out , again ! #1
scesnick
Garrett County Md. ( Western Md.)
Kubota MX5100
I have been having an ongoing problem with my 200bd 4wd system. I have a front pinion gear that is stripped. Well, I HAD to fix my road because of spring errosion, so, I put it back together with the worn gear but did not use the 4wd. It runs fine in 2wd. I used it for maybe 3-4 hours and darned if the balls didn't fall out of my drive shaft again !! and i wasn't even in 4wd. I have no idea why. The best I can figure is that the 2 springs on the rear of the differential is getting weak and allowing the shaft to move a little too much.
Any other ideas???
/ balls fell out , again ! #2
scesnick said:
........ The best I can figure is that the 2 springs on the rear of the differential is getting weak and allowing the shaft to move a little too much.
Any other ideas???
Scesnick, I've done my fair share on different models and I think it just has to be spring pressure on the shaft.
It takes quite a bit of effort to pre-load the springs, washer and pin. I have to use both hands to slide the spring assembly back, lock it down with needle nose Vicegrips (that works great) and gently align and release the 'grips'.
IMHO - There would have to be extensive damage and missing material at the end of you pinion gear at the ball pockets to Not hold the shaft assembly in place.
Mark
/ balls fell out , again ! #3
make sure that you have all the parts . I think there is a drive pin through the drive shaft then a washer then the spring. Mabe the spring has lost tension to keep your balls from falling out. I'am glad my balls don't fall out, there too much trouble to put back ! :D
/ balls fell out , again ! #4
I'd just like to add that my balls have never fallen out either....... though i have taken them out intentionally a couple times. I hope you do get your shaft straightened out !
/ balls fell out , again ! #5
Just curious, are these balls in the knuckle of the universal joint? Like the old Willys jeeps?
CAT 631C Lift Cylinder (A68134)
CAT 631C Lift...
Skidded fuel cell (A67714)
Skidded fuel cell...
500 BBL FRAC TANK (A67714)
500 BBL FRAC TANK...
335 GAL WATER TANK (A68842)
335 GAL WATER TANK...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2018 Chevrolet Tahoe SUV (A66738)
2018 Chevrolet...
