I know this is real long, but a lot of info here..
FYI, we have had Deere refuse warranty on a couple of front end repairs due to the following not being followed
REAR
BALLAST REQUIREMENTS
Shown below are minimum rear tractor ballasting requirements for 400 Series Loaders.
Cauton: To help prevent the possibility of personal injury or death caused by tractor/loader rollover, DO NOT operate tractor/loader without liquid ballast in tires at minimum tread setting.
IMPORTANT: Total ballast requirements consist of:
An optional choice for wheel weighting, plus
Mandatory 3-point hitch weight.
410 LOADER—With 4010, 4100, 4110, and 4115 Tractors
Tread Width
Rear Tires with 6 Wheel Weights
Rear Tires with Liquid Ballast
Minimum 3-Point Hitch Ballast
Minimum
4WD, Ag. Tires
X
350 kg (770 lb.)
4WD, Turf Tires
X
340 kg (750 lb.)
4WD, Bar Tires
X
340 kg (750 lb.)
4WD, Ag. Tires
X
405 kg (895 lb.)
4WD, Turf Tires
X
330 kg (725 lb.)
4WD, Bar Tires
X
330 kg (725 lb.)
419 LOADER - With 790 Tractor
Minimum Tread Width - All Tires 1018 mm (40.1-in.)
Tires
Rear Tires Without Liquid Ballast
Rear Tires With Liquid Ballast
Front
5.00-15, 6 PR F2
Loader use not approved
X
280 kg (617 lb.)
25 x 8.50-14, 4 PR R3
X
280 kg (617 lb.)
7-14, 6 PR R1
X
280 kg (617 lb.)
Rear
11.2-24, 4 PR R1
X
280 kg (617 lb.)
13.6-16, 4 PR R3
X
280 kg (617 lb.)
420 LOADER—With 4200 and 4210 Tractors
Tread Width
Less than 1500 mm (59.0-in.)
4WD, All Tires
Greater than 1500 mm (59.0-in.)
4WD, All Tires
X
300 kg (661 lb.)
4WD, All Tires
X
250 kg (550 lb.)
420 LOADER—With 4300, 4310, 4400, and 4410 Tractors
Tread Width
4WD, All Tires
4WD, All Tires
X
350 kg (770 lb.)
4WD, All Tires
X
250 kg (550 lb.)
420 LOADER—With 870 Tractor
Tread Width
Rear Tires without Ballast
Minimum
2WD, Ag. Tires
X
450 kg (990 lb.)
4WD, Ag. Tires
X
400 kg (882 lb.)
2WD, Turf Tires
X
310 kg (683 lb.)
4WD, Turf Tires
X
290 kg (640 lb.)
Maximum
2WD, Ag. Tires
X
260 kg (573 lb.)
4WD, Ag. Tires
X
200 kg (441 lb.)
2WD, Turf Tires
X
180 kg (397 lb.)
4WD, Turf Tires
X
170 kg (375 lb.)
430 LOADER—With 4300, 4310, 4400, and 4410 Tractors
Tread Width
Rear Tires with Liquid Ballast and Six Wheel Weights
All Tires
All Tires
X
600 kg (1320 lb.)
All Tires
X
550 kg (1210 lb.)
430 LOADER—With 970, 990, and 1070 Tractors
Tread Width
Minimum
2WD, Ag. Tires
4WD, Ag. Tires
X
400 kg (880 lb.)
2WD, Turf Tires
X
240 kg (530 lb.)
4WD, Turf Tires
X
235 kg (520 lb.)
Maximum
2WD, Ag. Tires
X
350 kg (770 lb.)
4WD, Ag. Tires
X
400 kg (880 lb.)
2WD, Turf Tires
X
240 kg (530 lb.)
4WD, Turf Tires
X
235 kg (520 lb.)
460 LOADER—With 4500, 4510, 4600, 4610, 4700, and 4710 Tractors
Tread Width
Less than 1600 mm (63.0-in.)
All Tires
Greater than 1600 mm (63.0-in.)
All Tires
X
600 kg (1320 lb.)
ADDING BALLAST TO 3-POINT HITCH
Weight can be added to the ballast box by adding material such as sand, concrete, or portland cement. If more weight is required, tractor Quik-Tatch weights may be used. A ballast box extension is available to increase capacity of box. See Attachments section.
A 3-point-hitch-mounted implement may be used as ballast, but it must meet weight requirements of the ballast chart. See your John Deere dealer.
CALCULATED BALLAST
UNIT
SAND
CONCRETE
PORTLAND CEMENT
Empty Ballast Box
40 kg (88 lb.)
40 kg (88 lb.)
40 kg (88 lb.)
Ballast
240 kg (528 lb.)
314 kg (692 lb.)
420 kg (926 lb.)
Empty Extension
3.6 kg (8 lb.)
3.6 kg (8 lb.)
3.6 kg (8 lb.)
Ballast with Extension
80 kg (176 lb.)
104 kg (230 lb.)
140 kg (308 lb.)
Total Weight
363.6 kg (800 lb.)
461.6 kg (1018 lb.)
603.6 kg (1330 lb.)
If the loader is equipped with a forklift or round bale fork attachment, additional ballast is required on the 3-point hitch.
TRACTOR
ADDITIONAL BALLAST
870
85 kg (187 lb.)
4100
85 kg (187 lb.)
