Ballast ballast box filling
/ ballast box filling #1
blackbird
JD 2520. what are you guys filling the ballast box with? I use a loader for light duty and a front plow for snow. I have seen some filled with concrete but I have seen others with removable lead or sand bags. What are you guys doing. thanks.
/ ballast box filling #2
I don't use a ballast box but if I did I would definitely use removable weight.... retaining wall blocks, actual weights (exercise), ect... Anything that can get the thing loaded up. I'd want something that were easily removable so the box could be moved by hand if needed. I have tons of extra retaining wall block so that's what I would use....
For my tractor.... I use my 54" Box Blade along with 10 JD case weights I've accumulated over the last few years...
/ ballast box filling #3
I used 50lb bags of sand. I leave them in the bag so I can remove them if I want and it turns out that two bags fit absolutely perfectly side by side in the box to form an ~4-5" layer. I use 7 bags total (350lbs) which I leave in all the time then have another ~150lbs in quick tach weights which I add on top for the really heavy jobs. Coupled with the ~170lb box, I end up between 520 and 670 lbs. For really light work (dry mulch), I only add the 150lbs quicktach weights to either round stock bar on 3pt or 75lb sub-soiler. I usually try to use the lightest ballast I can for my yards sake while still being keeping things stable.
/ ballast box filling #4
Morning Blackbird.
I went to my dearlership purchase second hand weight for almost nothing than built frame...3pins to hook up plus bumper for protection.
If you have the time and tools build something that's going to last...and last.
/ ballast box filling #5
My box is filled with concrete. I went to the local "U-Cart" concrete place, you know the ones that rent the little trailers filled with pre-mixed concrete...anyway, I took the box on my trailer and they filled it up for $40.00. They though I was a little crazy, but it was sure easy for me!
Also, be sure to caulk or tape the inside seams before you fill it or the water will run out and make mess!
/ ballast box filling #6
I use concrete pavers (I think they're 4"x4"x1.5"). Get 'em from the home center. They're dense, stack nicely, and are easy to take out. I could do a wheelie with my X585 if I filled the box entirely up with them. Sand didn't seem as dense.
/ ballast box filling #7
I filled my Ballast box on my 2210 3/4 full with sand and then set 10 - 42lbs. J D suitcase weights on top of the sand. Then you can reduce the weight in the box if needed. I had the ballast box sprayed inside with rhino liner to keep it from rusting. I figure 700+ with the ballast box, sand and weights. The weights are set just low enough to put a plexiglass cover on box to keep the weather out.
/ ballast box filling #8
I went with what I had available. I shoveled in gravel from my driveway repair stockpile. That settled down after a while and I use the space to store chain.
I figure that if I have to empty the box for some reason, I could manage to get the gravel out. Mostly, it was what I had available.
/ ballast box filling #9
blackbird,
I used solid concrete blocks 8"x4"X16". You can find them at home centers next to the standard masonary block. They also come in 2" thick and I used a few of these for fillers. If you are storing your ballast box on a hard surface such as a garage floor, a heavy duty furniture dolly is handy. Set the ballast box on the dolly before removing it from the tractor. Makes it much easier to move around and to re-attach to the tractor.
Jeff
/ ballast box filling #10
Thomas said:
Morning Blackbird.
Thanks Thomas, that's a great idea. I even have several tractor suitcase weights already. I like your bumper idea too!!! ;)
/ ballast box filling #11
I currently have mine filled with a collection of medium sized rocks/boulders and then filled in with pea gravel. This allows the water to drain and will let me empty the box out if I want to do something different. I keep an "extra" large boulder that I can set on top if I need the extra 75 lbs or so.
/ ballast box filling #12
Thomas said:
Morning Blackbird.
That is actually kinda kool looking. I thought about doing something like this, but then I moved and gave away my mig welder.
/ ballast box filling #13
I had mine for a while filled with free weights the only plus I guess is that I knew how much i exactly had in the box. Downside, it always clanked around and was noisey. I need the weights again for excerise purposes (decided to lift again) so I decided to fill it will portland cement, and I think it gives information on how much it weights after filling with different types of cement. I guess at least 800 lbs with the portland cement which is smoother and heavier than other types....plus side is no more noise and it was cheap to fill. I never use the weight box anymore since I have loaded tires and a backhoe hanging off the back....
Duc
Lincoln Electric Shield-Arc SAE-400 - Radiator Missing - For Parts or Rebuild (A63689)
Lincoln Electric...
PALLET OF MISC METAL (A63291)
PALLET OF MISC...
2020 Deere 544L (A60462)
2020 Deere 544L...
2019 CHEVROLET SILVERADO CREW CAB TRUCK (A59823)
2019 CHEVROLET...
METAL SIDES FOR HARDEE TRAILER (A63291)
METAL SIDES FOR...
UNUSED WOLVERINE 6' SLIP ON FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
