Ballast Block
/ Ballast Block #1
keeney
Minnesota
JD 4100 HST
Ballast block for use with my 4100 / 410 loader.
10-1/2 sacks of quick-crete.
Two 3/16" flats with 3/4" hole dilled through the end welded to an off-the-shelf cat-1 drawbar.
Some additional rebar thrown into the forms in case it cracks.
Estimated weight = 900 lbs.
I tapered the front so it nestles tight to the tractor - it only protrudes about 10 inches past the lift arms.
- Rick
/ Ballast Block
I chamfered the back corner to further help avoid backing into things.
- Rick
Misc. Pipe Lot 1 1/4", 2", and 3" Poly Pipe (A62679)
Misc. Pipe Lot 1...
(1) New 7ft Chain Sling (A65579)
(1) New 7ft Chain...
2013 Ford Taurus AWD Sedan (A64194)
2013 Ford Taurus...
New/Unused Landhonor Quick Attach Receiver Hitch Adapter (A65583)
New/Unused...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
Landhero LDH-TWP80, Gasoline Water Pump (A62679)
Landhero...
