ball joint
/ ball joint #1
chickenman
i have to replace the rubber boot on the right side crosslink on a 4310 has anyone removed the ball joint and how did you do it?
/ ball joint #2
I broke the steering cylinder shaft on my 4310 and I removed that ball joint with a air hammer. I took a flat drift bit and hit on the casting on both sides and it came right off. You could use a pickle fork and a hammer but it would tear the greese boot. Which might be what you are replacing? No air hammer!? get your biggest hammer and hit on one side of knuckle or take two hammers and hit both sides at the same time. Loosen the castle nut but leave the nut on and you will know when it popped free.
/ ball joint #3
I tore a hole in the grease boot on my 970 with loose tire chains. Used a tapered-ball joint forks and hammer.
The boot has a spring tension ring (recessed into the boot) and it comes right off with a flat-blade screw driver.
Best of luck.
AKfish
/ ball joint #4
Any tips for getting a new boot on?
I tore one on my 4120, ripped the replacement, and have yet to install the new one I have here.
Thanks,
Jon
2008 GMC C7500 WATER TRUCK (A67714)
2008 GMC C7500...
2012 PETERBILT 388 (A67714)
2012 PETERBILT 388...
MINI ROCK GRAPPLE (A61572)
MINI ROCK GRAPPLE...
2024 X-Pro Hawk Dirt Bike (A66738)
2024 X-Pro Hawk...
2011 Jeep Grand Cherokee Laredo SUV (A61574)
2011 Jeep Grand...
2014 HAMM HD+140I DOUBLE DRUM ROLLER (A65056)
2014 HAMM HD+140I...
