bale weight on john deere 327 square baler
   / bale weight on john deere 327 square baler #1
eibb
burlington, ct
case, jd, ih
does anyone have info on how to adjust bale weight on jd 327 square baler
   / bale weight on john deere 327 square baler #2
All I know is:
You can lengthen the bale to make it bigger and heavier;
or you can adjust the tension, which makes the bale tighter and heavier.
Of course, you can overdo it and break something too. :confused3:
   / bale weight on john deere 327 square baler #3
All I know is:
I agree! I like a 40 lb bale if I have to put it in the barn and 60 lb bales if I am hiring labor to put it in the barn. Ken Sweet
   / bale weight on john deere 327 square baler #4
Bales can be made heavier/lighter by turning cranks(parts key #5). If bale isn't hevy enough with cranks tightened down all the way one can add re-stricters (parts keys #21 & #22) 2nd photo. Depending how many bales baler has baled the parts key #21(cabbage cutter) has be known to wear smooth.
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
New Long Forks (A53002)
New Long Forks...
Kubota 24in Quick Attach Compact Excavator Tooth Bucket (A52748)
Kubota 24in Quick...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
PREVIEW DATES AND TIMES (A51573)
PREVIEW DATES AND...
2023 Club Car Carryall 700 Utility Cart (A51691)
2023 Club Car...
