bale weight on john deere 327 square baler
   / bale weight on john deere 327 square baler #1
eibb
burlington, ct
case, jd, ih
does anyone have info on how to adjust bale weight on jd 327 square baler
   / bale weight on john deere 327 square baler #2
All I know is:
You can lengthen the bale to make it bigger and heavier;
or you can adjust the tension, which makes the bale tighter and heavier.
Of course, you can overdo it and break something too. :confused3:
   / bale weight on john deere 327 square baler #3
All I know is:
I agree! I like a 40 lb bale if I have to put it in the barn and 60 lb bales if I am hiring labor to put it in the barn. Ken Sweet
   / bale weight on john deere 327 square baler #4
Bales can be made heavier/lighter by turning cranks(parts key #5). If bale isn't hevy enough with cranks tightened down all the way one can add re-stricters (parts keys #21 & #22) 2nd photo. Depending how many bales baler has baled the parts key #21(cabbage cutter) has be known to wear smooth.
2017 JEEP PATRIOT (A51406)
2017 JEEP PATRIOT...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
1999 Volvo VN Truck, VIN # 4VG7BBRFXXN772814 (A51572)
1999 Volvo VN...
1985 Eager Beaver 9D0W Tri-axle Flatbed Equipment Trailer (A50322)
1985 Eager Beaver...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
