Bale Spear
/ Bale Spear #1
meledward23
too close to Graceland....
1025R
I am thinking of getting a small tractor to move round bales around. What is the smallest size tractor that can handle a round bale on a 3ph.
Round bales dont weigh to much so most small tractors should be able to handle it.
Can a small 25hp with turf tires handle one. I suppose a suitcase on the front would be necessary.
(for those that really like details: I need a tractor around my small 1.5 acres. I have access to a 55da (still in the family) at the farm. The 55da spends most of its time moving hay bales, dragging the arena, and chomping on some grass. So I am thinking of getting a small tractor to put around the house and when I need the loader and a "real tractor" I can take the small tractor to the farm and leave it there so hay bales can be moved around and I don't have to run the 55DA back and forth as often, cause honestly hauling it is a PITA)
So I am wondering how small can reliably and conveniently handle round bales? I am wondering what is to small will it have lift and clearance issues. I have NEVER used a bale spear. The 55da moves hay bales with forks. The farm is not flatland, it has small rises and ditchs (nothing serious but it undulates)
Thanks,
/ Bale Spear #2
A 25 hp tractor can lift a round bale on the 3point. The 3 point capacity would be about 1600lbs. The tractor would have to be a compact as a sub compact wouldn't be able to lift the bale high enough to get it to clear the ground. With a compact any cat 1 bale spear set up should fit just like any other implement.
/ Bale Spear #3
A lot of it will come down what size bales you need to move. The smallest rounds can weigh as little as three or four hundred pounds and on up to a ton for the largest ones. The average around here depending on size is going to between 800 and 1200 pounds.
/ Bale Spear
You know what, anyone have picture(s) (hyperlink to pic) of a compact with a bale on a 3ph spear? That would probably answer my questions faster than words.
Lifting capacity really isn't my concern. Its clearance, again never having used a 3ph spear I really dont know what to expect out one.
/ Bale Spear #6
This is my favorite pic for round bale moving!
/ Bale Spear #7
Lifting capacity should also ne a concern as also weight of the tractor. You mentioned that your farm is somewhat hilly so stability is also a factor. My JD is around 6k lbs. and the are times when I think I could use some more weight and a wider stance. Good luck.
/ Bale Spear #8
This isn't a round bale but a 1200lb square bale on the back of a 26HP sub compact.
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
2013 FREIGHTLINER Cascadia (A61307)
2013 FREIGHTLINER...
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
2011 BIG TEX 40 GOOSENECK (A60736)
2011 BIG TEX 40...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
