Bagger cost shock
/ Bagger cost shock #1
chucko
Polk Co , Fl
bx1800
well I priced a bagger for my bx1800 and was shocked to find the proce was around $1500. I dicided I really did not want one that bad
/ Bagger cost shock #2
I too looked at the bagger unit for my B2410. Yup...way tooo much $$$ /forums/images/graemlins/blush.gif
I've started looking at other options.
Kevin
/ Bagger cost shock #3
Chucko,
I too find some of the prices to be excessive. Too bad, Kubota would have sold at least two more units (one to me and one to you) if the price had been more reasonable. So instead of paying Kubota's exorbitant price, I bought a $200 leaf sweeper that I tow. Now I can even pick up thatch, which a bagger will ignore.
/ Bagger cost shock
Is anyone making an aftermarket bagger that will work on a BX
what are the other SCUT makers doing/ charging...Think one of theirs would work?
/ Bagger cost shock #5
I suppose it's possible. I have seen some Kubota models that had an additional fan on the mower deck output chute. Maybe that's where some the the $2300+ cost comes from.
I'd like to see an after market company make stuff like that for these CUTs. I wonder if an after market motorcycle company would do something like that?
I'd like to have a quieter muffler.
/ Bagger cost shock
Form what I could tell about the BX bagger the blower runs off the 540 rear pto..
Anyhow if you guys run across one at a good price or aftermarket let me know
/ Bagger cost shock #7
I have the bagger, but I can honestly say that if my wife hadn't insisted, I would not have sprung for that kind of money. But that was her condition on getting my BX, so how could I argue? Anyhow, the bagger does an excellent job at picking up grass as well as leaves. The blower is indeed run off the rear PTO.
Bottom line from my perspective, it works great but it is a pain in the neck to mount/dismount.
This link may give you some information and also links to another that I had started as well.
http://www.tractorbynet.com/forums/showthreaded.php?Cat=0&Board=owning&Number=318667&page=&view=&sb=5&o=all
/ Bagger cost shock #8
chucko,
You are correct the bagger does run off the rear PTO. It is shaft drive as well using two right angle gearboxes to get power to the impeller. It works very well keeping up with the large BX mower. My only complaint is the fabric collection bags. For the volume and capacity of the BX I would have preferred a hard clamshell design one could back up and operate to self unload, ahh the GCK600, but it is only available overseas /forums/images/graemlins/mad.gif
As for alternates the Trac-Vac units are well built and come with either a gas engine or PTO drive. However they cost more than the Kubota unit /forums/images/graemlins/frown.gif You could try a tow behind unit like the Swisher
Good luck,
Michael
/ Bagger cost shock #9
surfran,
The trick I was shown to dismount was to lower the legs and then push the top towards the tractor to disconnect the top link and then the lowers. Remounting was the reverse. This worked like a charm.
Level ground is a must as well.
Hope it helps,
Michael
/ Bagger cost shock #10
Possibly we can find someone overseas that would be willing to ship a few of the European style grass collectors stateside. I would buy one in a heartbeat, but I am not impressed with the design of the 3 bags. I don't understand why Kubota builds a great tractor and then lets down the ball when it comes to the grass collectors.... /forums/images/graemlins/frown.gif
/ Bagger cost shock #11
Anybody tried a mulcher set up? If I get a BX2200, I'll expect to install mulcher style blades, etc.. Made a big difference on my Deere 345 - no raking /forums/images/graemlins/smile.gif, of course, if a bagger is intended for leaves, I always left leaves where they fell.
/ Bagger cost shock #12
PCMEM,
Thanks, I have also tried that. It works fine on removing, but I didn't have much luck installing. I always mount/dismount it in my garage floor that is level and solid as well.
I mostly use my bagger for when I let the lawn get too high, and of course the leaves in the Fall (can't beat it for those).
I also am impressed by the European version with the clam shell, but suspect that would be even more costly.
/ Bagger cost shock #13
I have the mulching kit and blades on mine, it does a decent job,not as good as a walk self-propelled mulcher though . Of course, if You have used one before ,You know you will have to slow it down some and make sure the grass is dry.
The mulching blades are a little over $40.00 and the kit is over $200.00, The kit does not include blades.
I had mine put on before delivery and mow about every three days.
I am going to the Dealers to order a set of blades tomorrow and will be glad to let You know the exact price if You want to know.(mine is the 60" deck)
/ Bagger cost shock #14
here is the cost and part number of the mulching blades for a 60" deck:
Original Part Number 70000-25020
Current Part Number 70000-25020
Description BLADE, MULCHING MOWER
Price Each $13.35
My dealer charged $14.69 each for the blades.
2009 ALLMAND MAXI-HEAT MH1000 HEATER TRAILER (A67714)
2009 ALLMAND...
GENERAC MOBILE PRODUCTS MLT6S LIGHT PLANT (A68842)
GENERAC MOBILE...
2016 Freightliner M2 106 Brush Hawg Grapple Truck (A66736)
2016 Freightliner...
2009 PETERBILT 388 FLATTOP SLEEPER (A67714)
2009 PETERBILT 388...
Mercury Outboard Boat Motor (A66738)
Mercury Outboard...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65056)
2021 WEILER K560...
