Bad Wheel
/ Bad Wheel #1
Frank Sorbello
Power Trac PT-422
Anyone have the specs on the wheels for the PT-422 or know where to buy them other than Power Trac? I need to replace one. Tire size is I believe 23 x 12.5 x 10. 5 lug
Thanks
Frank
/ Bad Wheel #3
Do you think this set up will work?
I doubt that wheel is designed for the kind of weight/stress you would be putting on it.
what happened to the wheel?
/ Bad Wheel
Hi
So I purchased 4 tires and wheels from Surplus Center.
They seem to be very very similar to the Carlisle tires that are on my machine. Tread pattern looks pretty close to identical.
Wheels seem to be very close as well.
I did notice on my present wheels and tires. I have a valve stem on the inside and outside of each wheel.
On the new wheels there is only one, which will be on the inside or deep side of the wheel. It appears it will be very close to hitting the wheel motor frame.
Any insight on this?
Thanks
Frank
/ Bad Wheel #11
I have been very happy with my recessed valve stems. I no longer have to worry about sticks etc ripping them out. But I also have the bullet proof sealer in these tires so I have not had to add air to them in over a year.
Ken
/ Bad Wheel #12
Just drill a new hole for the valve stem where you want it to be.
Either use the other stem or remove it and weld shut.
/ Bad Wheel #14
You can also just put a valve stem in there and never use it. Remove the core if you want. Or paint it red if you can't remember.... like me! :laughing:
Ofa Eko 8 studded tire chains
Ofa Eko 8 studded...
JOHN DEERE QUICK HITCH (A64278)
JOHN DEERE QUICK...
2015 Ford F-650 Altec AP40 35ft. Bucket Truck (A64194)
2015 Ford F-650...
2015 International WorkStar 7500 29Yd. Side Loader Garbage Truck (A64194)
2015 International...
More info coming soon. (A64557)
More info coming...
2014 Ford F-150 Pickup Truck (A64556)
2014 Ford F-150...
