BAd TAch on BX2350
   / BAd TAch on BX2350 #1
Alan Davis
Brownsville, KY
Kabota BX 2350D
Anyone else have a tachometer go out on their Bx2350. The digital readout is unreadable. Took the dash apart to see if there might be a loose wire. No luck the LED is soldered to the board. Called my dealer and they tell me you have to purchase the entire panel assembly which costs just over $200.
Of course the hour meter is out also so I (as much as I hated to ) ordered the new assembly.
Just wondered if any others have had this problem.
   / BAd TAch on BX2350 #2
I havent had a problem on mine yet. During the winter when its really cold out, i noticed it would be dim, but barely still readable. Havent had to worry about it yet for almost 4 years. Do you still have lights on the digital readout when you turn the headlight on? IF not, then its either burned out completely or wiring issue for sure.
2013 Hyundai Azera Sedan (A50324)
2013 Hyundai Azera...
2016 Ford Explorer AWD SUV (A50324)
2016 Ford Explorer...
2011 PETERBILT 348 (A52472)
2011 PETERBILT 348...
2017 Buick Encore SUV (A50324)
2017 Buick Encore...
CFG Industrial QK20R (A50121)
CFG Industrial...
14" Pipe Ditch Lift Pump (A50121)
14" Pipe Ditch...
