Bad short across fusible link on LB1914
   / Bad short across fusible link on LB1914 #1
bro
I've got a direct short that blows the 30 amp fusible link on my LB1914. I have disconnected most all the componenets and then reconnected testing with a test light with each connection. The short shows when I connect the votage regulator multi-pin. Will a faulty regulator cause a short or is there a short in one of the wires in that circuit? Any help would be appreciated.
   / Bad short across fusible link on LB1914 #2
This is my first reponse to the TBN. I had the same issue with my LB1914 a couple years back and it ended up being the voltage regulator. I was fortunate enough to have a friend that loaned me one for trouble shooting purposes and when it resolved the issue, i purchased it, around $100 if I remember correctly.
Thanks. I was able to diagnose the problem and it was in fact the voltage regulator too. Kioti must have had a weak batch of those things.
   / Bad short across fusible link on LB1914 #4
Great post and response, thanks for the useful information!!
HYD AUGER W/ 10" BIT (A52708)
HYD AUGER W/ 10"...
2017 Ford Explorer SUV (A56859)
2017 Ford Explorer...
2014 F-150 STX (A56435)
2014 F-150 STX...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
JOHN DEERE 1560 - 15' NO TILL GRAIN DRILL (A52708)
JOHN DEERE 1560 -...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
