Bad short across fusible link on LB1914
   / Bad short across fusible link on LB1914 #1
bro
I've got a direct short that blows the 30 amp fusible link on my LB1914. I have disconnected most all the componenets and then reconnected testing with a test light with each connection. The short shows when I connect the votage regulator multi-pin. Will a faulty regulator cause a short or is there a short in one of the wires in that circuit? Any help would be appreciated.
   / Bad short across fusible link on LB1914 #2
This is my first reponse to the TBN. I had the same issue with my LB1914 a couple years back and it ended up being the voltage regulator. I was fortunate enough to have a friend that loaned me one for trouble shooting purposes and when it resolved the issue, i purchased it, around $100 if I remember correctly.
Thanks. I was able to diagnose the problem and it was in fact the voltage regulator too. Kioti must have had a weak batch of those things.
   / Bad short across fusible link on LB1914 #4
Great post and response, thanks for the useful information!!
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
Land Honor Quick Attach Power Rake (A50514)
Land Honor Quick...
2013 Nissan Rogue S SUV (A50324)
2013 Nissan Rogue...
Electric Forklift Pallet (A50322)
Electric Forklift...
2007 Astec RT-360 Ride-On Trencher Backhoe (A50322)
2007 Astec RT-360...
