Bad news big repair
   / Bad news big repair #211
The funny thing here is there is a relay between the battery and the GP's... The ECU probably does not have a clue if the GP's are even there or not ..... Was it ever tested to see signal came from ECU to energies the relay..... So much speculation, no facts from diagnostic results.
This is head to the 213 page thread on how to remove a stripped drain plug....
   / Bad news big repair #213
This is what you need. :ROFLMAO:
   / Bad news big repair #215
Up in northern Canada we use Espar engine heaters. They run off the machines electric and fuel systems and are amazing little units. You can even program it to start up on its own at a predetermined time. Otherwise just hit the start button and give it a hour or 2 depending on how cold it is. Last one I purchased was around $1400 CDN.
   / Bad news big repair #217
but after about the 20th bypass switch suggestion and about the 12th AC block heater suggestion, few paid attention to my desire to fix the original system????
Some people don't read the thread, they read the last page. They also don't know how to fix the original system. What's your fuel consumption at idle? Could you just let the tractor idle overnight?
   / Bad news big repair #218
Wonder how long the tractor would be down waiting on them to rebuild the ECU?
   / Bad news big repair #219
No, I can’t prove it works. 2 years ago, the light would flicker, for a fraction of a second.
But even if the dash light was out, there’s no glow plugs whatsoever. Starting is rough.
My M126x (pretty much the same tractor, just 9 less HP) has glow plugs functioning properly and starts perfectly.
Here is a thought. What if you tried the ECU out of the M126X to see if it would fire the glow plugs? At least then you would know if there is a problem with the ECU. Of course if it blows the glow plug circuit you will need two bypass switches. But that is cheap enough.
I thought of trying that last year, but I ran it by someone who was an electronics tech in the military and he thought it would not be a good idea since the tractors have different programming.
300 GALLON PORTABLE FUEL TANK (A51247)
300 GALLON...
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
2016 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2016 Crane Carrier...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
Quick Attach EZ Axe Skid Steer Tree Shear (A53472)
Quick Attach EZ...
2015 Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
2015 Crane Carrier...
