Bad head gasket ?
/ Bad head gasket ? #1
Jimmy6657
Case275
I have a 1974 international 2400a 3 cyl diesel. Runs good doesn’t seem to smoke more than usual but oil is grey and overfull. Are these known for head gasket or is it something more serious ?
/ Bad head gasket ? #2
Are you losing water? Some models if fuel pump leaks can put diesel fuel into the oil.
Take a sample of the oil and put in a clear jar or glass and let sit. Then you can see what separates out. Another test if water is drip some in a warm
Pan does it sizzle and steam? Be careful if you try that though since the steam bubbles might burst spraying hot oil.
/ Bad head gasket ?
Thanks for the info I will try those tests
John Deere 7700 (A64119)
John Deere 7700...
2012 VOLVO DBL SLEEPER ROAD TRACTOR (A62130)
2012 VOLVO DBL...
(5) MISC WHEELED TRASH CANS (A64280)
(5) MISC WHEELED...
3144 (A63117)
3144 (A63117)
2015 KOMATSU PC360LC-10 EXCAVATOR (A64279)
2015 KOMATSU...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
