Bad head gasket ?
/ Bad head gasket ? #1
Jimmy6657
Case275
I have a 1974 international 2400a 3 cyl diesel. Runs good doesn’t seem to smoke more than usual but oil is grey and overfull. Are these known for head gasket or is it something more serious ?
/ Bad head gasket ? #2
Are you losing water? Some models if fuel pump leaks can put diesel fuel into the oil.
Take a sample of the oil and put in a clear jar or glass and let sit. Then you can see what separates out. Another test if water is drip some in a warm
Pan does it sizzle and steam? Be careful if you try that though since the steam bubbles might burst spraying hot oil.
/ Bad head gasket ?
Thanks for the info I will try those tests
2019 Kenworth W900 Ext. Day Cab w/ Wetline (A62613)
2019 Kenworth W900...
2021 Ford F-150 4x4 Pickup Truck (A61573)
2021 Ford F-150...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
3 Point Hay Forks (A62613)
3 Point Hay Forks...
Takeuchi TB235-2 (A62177)
Takeuchi TB235-2...
Coleman Sky Lodge Instant Screen House (A62613)
Coleman Sky Lodge...
