Bad Boy Rogue zero turn mower
   / Bad Boy Rogue zero turn mower #31
BigBlue, have you noticed any issues with vibration in the control handles? I've been getting a lot of numb hands the last couple of years.
its progbably just the Advancing OldePhartitis...
   / Bad Boy Rogue zero turn mower #32
How well does the BadBoy suspension on their mowers work?
   / Bad Boy Rogue zero turn mower #33
I don't notice any vibration. My right hand does get a little numb when mowing, but I have a bit of carpal tunnel and it does the same thing when riding motorcycle. I also mow over 7 acres so I'm on the mower for 3.5 hours at a time.
   / Bad Boy Rogue zero turn mower #34
I think it is pretty good. I've never used another zero-turn with a suspension, but my 7 acres is somewhat bumpy and mowing with the Rogue is a big improvement over the Deere x758 tractor/mower I used to use. Rogue has both a real rear suspension as well as rubber isolators giving the front some cushion. And I have the upgraded suspension seat on the Rogue. The suspension and the quicker mowing time was a major factor in why I chose the Rogue.
2005 CHANDLER  500 BBL FRAC TANK (A58214)
2005 CHANDLER 500...
2016 Kawasaki Mule KAF620S 4x4 Utility Cart (A55973)
2016 Kawasaki Mule...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2014 AMERITRAIL LAY FLAT HOSE TUGGER TRAILER (A58214)
2014 AMERITRAIL...
IRON FORCE IMPACT SET (A58374)
IRON FORCE IMPACT...
2012 PROCO 130 BBL VACUUM TANK TRAILER (A58214)
2012 PROCO 130 BBL...
