Backwards running woods RFM?
/ Backwards running woods RFM? #1
jaybirdt
Holland New York
Iseki 1910f
Well, I think Ive done it now.I had a friend call me from an auction to tell me about a woods 48 inch rfm. I told him if it was decent bid on it for me as I was working.Got mower for a reasonable price but got it home and found a suprise.Mower has an 18 pline pto shaft and is set up to run counter clockwise.It says run with satoh and yanmar 135 and 155 do all these run a backwards pto or is the mower convertable with different blades and pto adapter? It is a woods RM48 thanks Jason
/ Backwards running woods RFM? #2
Post this in the Mitsubishi forum. There is always someone there looking for one. Kind of rare.
/ Backwards running woods RFM? #3
I don't believe the Yanmar models 135 & 155, or Satoh run backwards. If the RFM is fine spline it must be for a different model, as the above models are 1 3/8" 6 spline standard.
Mark
/ Backwards running woods RFM? #4
The Yanmars don't run backwards, but some of the small Satohs, Mitsubishis, and I heard that there were a couple of small Kubotas that way. I have had one of the Mitsubishis and one Satoh that were 18 spline wrong direction PTO'd. /forums/images/graemlins/crazy.gif
It has a woods decal on it that says run Satoh Beaver and Kubota in 2nd pto speed 800-1000 rpm and Yanmar 135,155 at 1000 rpm thats why I thouhgt it might be convertable to standard pto because the yanmars are american models.Oh well, if anyone could find an oddball mower it would be me Thanks Jason /forums/images/graemlins/confused.gif
/ Backwards running woods RFM? #6
You might want to call Woods and see what they say.
/ Backwards running woods RFM? #7
Is this a straight gear box job.. or something with belts.. Depending on belt setup you may be able to flip the belt end ont he drive pulley, thus reversing direction.. now.. that creates other issues with blade direction, and if there is an ORC installed ont he blade spindle ( like on some IH belly mowers ).
Soundguy
The mower has a belt drive with the large pulley run directly by the pto shaft.I went on woods web sight and found manuals listed for model RM48 with two digits after YM,JD and SB mine says SB which I believe is for Satoh Beaver.Tomorrow I have to call Woods and find if it can be changed to be set up for JD or Ym with standard PTO size and direction.Have to call becuse now I blew up my email and it doesnt work or maybe I have to type my question to Woods counterclockwise /forums/images/graemlins/grin.gif
/ Backwards running woods RFM? #9
I replied on the Mitsubishi/Satoh forum. And I think there was a Yanmar and maybe even a Kubota with backwards PTO, but that was a long time ago.
Soundguy, there ain't no flippin the belt on this thing. You have to have a diagram with step 1, step 2 .... just to put this belt on. It's a B-124 belt if anyone wants to know.
/ Backwards running woods RFM? #10
Nope!, it's not just you. I got an auction RFM from a guy that has reverse rotation (but no goofy PTO). I found some Walker blades that had the cutting edge on the "wrong" side. After a bunch of grinding and fitting-up of the blades, it cuts good and I'm still at less than half the price of a new RFM. ... But I got 'er boy, and that makes me a winner ~ Bobby Bare! /forums/images/graemlins/grin.gif
/ Backwards running woods RFM? #11
Heard that song last week. First time in years. /forums/images/graemlins/grin.gif
/ Backwards running woods RFM? #12
Reversing the blades is now looking like a good thing.... easiest anyway.. from an 'onlooker' point of view..
Soundguy
/ Backwards running woods RFM? #13
I bought a used one about 10 years ago, not knowing it was a reverse PTO model, and it did have the 18 spline female pto. I had a parts deck that was my father's and was the correct rotation. Swapped the pto shaft and took a blade with me to order new blades. I started mowing and the blade bolts would not stay in. Swapped spindles too and fixed the problem. The blade bolts for standard pto rotation are left hand thread.
Just wondering did you have a problem with the belt tensioner? the guy at Woods told me the tensioner was different depending on the direction of rotation.Looking more and more like Im screwed.You dont need another backwards mower do you?cheap /forums/images/graemlins/grin.gif
/ Backwards running woods RFM? #15
Never had any trouble with mine. I think they are both the same but I could be wrong. I still have them both and will let you know. You might be able to sell it on the yahoo mitsubishi club.
/ Backwards running woods RFM? #16
The Woods guy was correct. The tighteners are on opposite sides. Maybe that's why I went through a belt a year. Gave my old rfm away Saturday. One spindle was broken and everything else was plumb wore out.
