Backup camera for watching rear implements?
   / Backup camera for watching rear implements? #11
Just received my new L2501 and would like a backup camera to view the implements etc behind me. (have multiple ruptured disc's in my neck).
Anyone know of any good options that are viewable in bright sun?
Golf cart mirror mounted on the FEL arm works pretty good. There's also a thread about that.
I'll take your word for it, but I'm not interested in traffic behind me or general safety lol.
I want to see the implement working without getting my neck to start hurting and ruining my night.
   / Backup camera for watching rear implements? #13
I got a $150 weather proof rated monitonotor for my old L3200. Think it was a Pyle. Even with a 1.5" or so hood it was still not bright enough for use on an open station machine. Keep thinking about trying for another bucket cam in the cab on my new L4060, but can't find one bright enough with a higher resolution (or the motivation to try that build again).
   / Backup camera for watching rear implements? #14
So everyone says the remote cameras don't work because too much sunlight to see the display. I get it; I can't see my cellphone in sunlight either. I'm back to the mirror idea. Thinking......
   / Backup camera for watching rear implements? #16
A couple of experiments that didn't work. Don't waste your time: Yanmars in Japan have a rear view mirror extended from the side of the hood like a motorcycle, probably to meet specs to drive on the road. I mounted a motorcycle mirror on that attachment point and found it worthless, too much vibration. Then I got out an old temporary towing mirror, the type for an old car towing a big camp trailer. I mounted the mirror head to the grab handle on my right fender and aimed it down to the box blade. Also useless, the field of view wasn't useful. Gave up.
   / Backup camera for watching rear implements? #17
There are rear-view mirrors that clip onto hat brims and helmets, usually for bicyclists and scullers. My wife has one for when she road-rides horses. Might try something like that.
   / Backup camera for watching rear implements? #18
I want a heads up display (instrument cluster) with rear view built into my sunglasses. Retina controlled if I am not asking too much.
   / Backup camera for watching rear implements? #19
I did it, mounted rear camera and the larger screen (5"?) but then I'm cabbed.
I use it mainly for snow blowing duties. Works great 4 me.
And PS, even if not rated for cold mine worked to -30 no problem.
My cab (a DIY) is all steel so I simply used a magnet to mount the screen center just under the front window.
Funny thing is when I blow snow with my flashing beacon on I get yellow blinking streams of snow on my viewer.
The built in guide lines aren't very accurate as I mounted my camera op high so as to not have any snow interfere however I got used to judging how much clearance I needed from the 'guide lines'.
Now those kits accept two cameras (very cheap) so you can also mount one on the FEL to see what U are loading.
One caution is the kits use extremely thin wire so you need to beef that up or somehow protect them as a tractor is a rather tough environment.
(I taped my wires to a heavier gauge wire as a precaution.)
If U are open station make up a sun shield for viewing and keep a plastic bag handy to ward off rain.
   / Backup camera for watching rear implements? #20
Do you have a cab? My concern, as I do not have a cab, is viewing a monitor in bright sunlight?
I don't have a cab. If the screen is dusty (which seems like always) it can be tough to view in bright sunlight, but when clean it's pretty decent. I had planned to make a hood over the screen but never got around to it. Maybe I'll do that tomorrow...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
1758 (A58375)
1758 (A58375)
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
18" PIN ON BUCKET (A52707)
18" PIN ON BUCKET...
2020 MACK P164T (A58214)
2020 MACK P164T...
