backing up with a cart
   / backing up with a cart #11
<font color=blue>Go watch some of the novice backers on a boat launch ramp</font color=blue>
No thanks! Been there, done that too many times... waiting my turn in line behind them!/w3tcompact/icons/laugh.gif
   / backing up with a cart #12
I have owned utes with canopies where rear vision is restricted for approx 5 years now.
Reversing with mirrors is my ONLY option. I had to learn it the hard way but now won't do it any other way.
Trailers are no worries !!
Cheers
   / backing up with a cart #13
Chris, et al, NEVER underestimate the comedic value of parking in the shade with a cool drink and watching the antics at a launch ramp. It isn't just the backing or the burning clutches or the folks burning their tires and going backwards on a wet mossy ramp. The occasional "forgot to put the drain plug in" is fun but the get out of the car with it in drive and not setting the brakes and then the engine dies and the WHOLE thing backs into the water while the folks involved run around like keystone cops crossed with the three stooges. There are object lessons in the p[arking lot too where folks might try to back up to their trailer and either can't find the hitch or takemore tries than the runaway bride to get hitched.
If you don't have good visibility of what you are backing it helps to put a couple pieces of lath, or fiberglass wands or whatever up, on in front and one in back so you can see the angle of your tow better. I back about as good as most folks I have ever watched with a minimum of real gaffs BUT when backing my new DR Chipper I have to be careful, go slow, pull up to straighten it out to try again etc. If I lower the tailgate of the Dakota I can see the chipper well but if I turn much the tailgate migt hit the inverted tongue prop (in its factory provided carry position). Done it twice. If I leave the tailgate up, I can't see the chipper well enough and it is easy to jackknife it. I need to put a couple of those bike flags on fiberglass wands on it on or near the centerline so I can see the angle it is making and if that angle is growing , maintaining, or what.
On the topic of trailers... I have a convex mirror about 6-7 inches in dia that I have a mount for that just sits on the tailgate and you can use it to see your hitch. Can use the rearview mirror or turn your head. You can see the trailer tongue before you contact and make corrections to line up perfectly if you aren't too far off to begin with. If needed, you can pull up, make one correction, and back up again acquiring your target and getting near perfect allignment everytime without getting out to look. I find that by putting a big white dot on top of the trailer hitch (trailer is black) it improves contrast and makes it way easier to see in the mirror and allows the system to work in the dark from your tail and backup lights. Couldn't keep a white dot on the ball itself, too dirty, so I just stick a piece of scrap paper on the top of the ball with available grease or spit and I can see the two dots merge while making a perfect docking manuver. A real simple and inexpensive solution to hitching trailers.
Patrick
   / backing up with a cart #14
When you say cart, do you mean trailer - as in fixed wheels near the center of the unit, or do you mean a configuration like a hay wagon where there are four wheels and the front ones turn? I've seen people try to back up hay wagons and it is definitely not easy. I can back up a trailer as good as the next guy, but forget the hay wagon - my brain doesn't work that way.
   / backing up with a cart #15
Try backing an articulating tractor with a trailer............
   / backing up with a cart #16
I use to work at an airport. You tow airplanes by the front wheel(s). They are just like hay wagons, as their front wheels turn when you push them. The best way to do it was to put the towbar on the front of the tug (tractor) and face it. It was incredibly easy that way. It works for wagons as well.
   / backing up with a cart #17
Speaking of towing, check out this Power Trac airplane towing package <A target="_blank" HREF=http://www.power-trac.com/airport.htm>Click here </A>
Before you get excited about the 13,000 lb towing capacity of the little PT400 series, check out the picture of the King Air that it is towing. I use to push those into the hangar by hand /w3tcompact/icons/laugh.gif It was faster than going to get the tractor and less of a chance of hitting the airplane with a machine or running it into the hangar wall or another airplane.
The point I'm trying to make is that I'm incredibly strong(just kidding). What I'm really trying to point out is how much easier it is to position something with a tractor when you are facing it.
   / backing up with a cart #18
I find it very easy /w3tcompact/icons/smile.gif I can't figure out why. It is much harder with my lawn tractor.
   / backing up with a cart #19
Yeah, I guess that's why all the marina pickup trucks I've seen have hitch balls on the front bumper. I figured it couldn't be for driving down the highway /w3tcompact/icons/laugh.gif. Could you imagine?
   / backing up with a cart #20
Your words sure bring back memories. A couple of us guys would skip an occasional class and go down to the ramp on the river and watch the antics. Exactly as you describe!! I must admit, I had a hitch on the front of the van as well as the back. That front one kept the drive wheels off the slime on the ramp, but it also made steering the trailer through the house gate to the yard much simpler. Thanks for the memory jog.....
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A57024)
2023 Unverferth...
2015 CATERPILLAR TL943C TELESCOPIC FORKLIFT (A52707)
2015 CATERPILLAR...
2023 John Deere 6155M MFWD Tractor (A53485)
2023 John Deere...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2006 Ford F-650 Terex Hi-Ranger TL37P 37ft. Bucket Truck (A55852)
2006 Ford F-650...
2008 Komatsu PC228 (A47477)
2008 Komatsu PC228...
