backing up with a cart
/ backing up with a cart #21
I have 2 trailers and to make it easier to hook up I put a cb ugly stick anttena on the tongue of each. I have a Leer topper on my truck and the word leer happens to be centered over my hitch. I just put the anttena between the two es and ease back until I feel a bump. I then put the truck in drive and then into park. I am generally less than half a ball off. I then let the tongue down until pressure is on the ball. Simple then to move the tongue until it drops over the ball.
/ backing up with a cart #22
<font color=blue>The occasional "forgot to put the drain plug in" is fun</font color=blue>
Be careful, Patrick, who you are laughing at. It might be me! Once I discovered the plug was missing after I got out in the bay and my buddy noticed water in the floor of the boat. I was fishing near a guide and his party in one boat and two buddies from work in another. I was embarrassed and so afraid they would notice that I ssshhh-ed my friend, cranked the motor and eased away where I could lean unnoticed over the back of the boat and put the plug in and then pump the water out with the bilge pump.
Another time I took my dad out and the same thing happened. I knew I had put the plug in and could not understand why the boat was filling up with water. I figured the plug had come out and headed home. Once I got the boat on the trailer and up the ramp I discovered what had happened. I had plugged the plug into the live well drain hole!/w3tcompact/icons/blush.gif How many times is one person allowed to make the same stoopid mistake? Until he gets it right or sinks, I guess!/w3tcompact/icons/laugh.gif
As far as having difficulty backing up the cart I am surprised no one has suggested lengthening the tongue on the cart. We all know that the longer the distance between the hitch and the wheels the easier a trailer or cart is to back up. At work we have a cart that we wag behind our golf cart and it is nearly impossible to back it up without jackknifing it. Part of my job also involves moving tank trailers with a mule (yard mover.) Backing up those long trailers is as easy as falling out of bed because of their length and the distance from the wheels to the pivot point on the fifth wheel.
I think practice is the best suggestion but if it is practical I would suggest lengthening the tongue by a couple of feet and see if that would not alleviate at least some of the backing up problem.
/ backing up with a cart #23
Speaking of plugs................
My last assignment in Germany was in a Float Bridge unit. They build pontoon sections to ferry tactical vehicles and armor across rivers or they can build a floating bridge all the way across a river. The boats used are 27' Aluminum with twin 6cy Saber Diesels and jet drives.
One day we were doing a bridging operation on the Rhine when one of the boats developed a problem with a drive. We took it out of the water and a mechanic did some work on it.
When he was finished, we put the boat back on the water with the operator and mechanic on board for a test run. As soon as the operator backed away from the shore, the boat went straight to the bottom.
We spent a couple of hours winching it back out and discovered that the mechanic had left the cover off of the drive leaving an 8" hole for water to get in the boat. A lot of water can move through an 8" hole pretty quick.
We had two engines full of river water and a red faced, and very wet mechanic.
/ backing up with a cart #24
mrcaptainbob, My pickup has a custom bumper on the front with all kinds of goodies, Solid stainless steel push bars, big hooks, brush gard, 12,000lb winch, for light, driving lights, and so forth as well as being made of 1/4 inch plate
B U T
Last and not least is two integral receiver hitches, one on each side of the winch. Can carry bikes or whatever but if manuevering ever gets too tough, I can always put a drawbar in front where I can see what is goin' on. Haven't used it for backin' a trailer yet but give me time, I'll get around to the original intended purpose eventually uinless Murphy takes a permanent vacation.
Patrick
/ backing up with a cart #25
cstocks, I like the bit aboput the live well plug. Good design would require different plugs. My wife and I were in coastal search and rescue for 10 years as well as doing vessel exams at places like launching ramps. We may not have seen it all but we saw plenty. You self rescued and no one had to come get you so give yourself some credit.
The truly funny ones are the "leave the plug on the dash of the tow vehicle with a note attached so it won't be forgotten" cases. Some folks think clearly under pressure, sort of. Guy calls Coast Guard on the emergency channel (Marine VHF Ch 16) and we head out the channel toward the open ocean. His call sounds ever more frantic, talking about kids on board etc. We get the 41 footer up on plane and haul a-- out the channel "code 3" when a high speed cruiser (about 35 ft) passes us going the other way that sure meets the desciption of the ailing boat. Seems his brain kicked in and he realized that the leak, a failed valve in the marine head (toilet) or a leak in the through hull fitting for same, was the cause and it was in the air when the boat was up on plane so he firewalled it and headed for the harbor police dock where there was a HD electric bilge pump for emergencies. Why he didn't have a good pump on board so many (marginally) floating dollars is beyond me. It would have been interesting to see what he would have done if the sea state would have been considerably less conducive to high speed ops.
Patrick
/ backing up with a cart #26
I thought I was the only nut who likes to watch the goings on at boat ramps !!
My friend and family can't work it out but there is always fun to be had.
Except if I am one of the boats in the queue !!!
/ backing up with a cart #27
Slow. Slow. Slow. If it's a two wheel trailer if you cut left it turns right, and if you cut right it turns left.
An RVer's tip. Put your hand at the bottom of the steering wheel, you cut left and it turns left, you cut right it turns right.
Slow. Slow.
That's right, a small 1,000 lb capacity sheet matal dump cart with fixed wheels near the center. If that qualifies as a trailer, then I guess I'm talking about a trailer. When I really run into trouble is when I pull up into tight quarters, like in the woods, and then have to negotiate my way out. Sometimes I end up unhitching the trailer and moving it manually to a better position, then reattaching it to the tractor hitch. Thanks for the input everyone.
/ backing up with a cart #30
Ramp ettiquette requires one to stay away from the ramp and its approaches until the vessel is completely rigged and ready for launch. Of course not everyone is vying for the Emile Post of the launching ramp award. Take the bozo with the new sailboat who hasn't a clue how to rig his mast (standing rigging) or to set up his running rigging (sheets, down/out hauls etc. and tries to figure it out by process of ellimination using an exhaustive search method that ensures he tries every possible combination and permutation in pseudo-random order ensuring that some arrangements are tried multiple times. My experience has been that the longer it takes, the less likely that it is done correctly in these evolutions.
I was at one time probably fun to watch at the ramp. I had a partial keel sailboat that sat way high on the trailier to clear the keel above the pavement. The trailer (hot dipped galvanized with stainless steel fenders) had a telescopic double extension tongue to allow backing the trailer WAY out in the water and not getting the tow vehicle in the water. Of course the tongue is only extended on the ramp and used to go in a straight line as it can't take the side force of a turn. You back the trailer down to the water leaving the tires out of the water, chock the wheels, crank down the tongue jack, unpin the tongue's first extension and pull the tow vehicle upo the rampo until fully extended and repin. Sounds easy BUT often some eager bozo has edged down toward you and is in the way, recall you can't turn now. Release second telescopic section, pull forward and pin that then take a strain on the trailer so yo can pull the chocks and back her in. This is not fun for just one person. As thre are frequently drop offs at the deep end of a ramp and you can't pull the trailer up over one of them with the boat on the trailer, launching is OK but retrieval requires high water as in high tide, yet another consideration in the planing stages.
Actually, the most entertaining I think we ever were at a ramp was when my buddy fired up the inboard auxilliary engine on a small sailboat of mine and had a pretty advanced throtle setting and since it had a centrifugal clutch the boat took off down a line of small rental boats with him fending off with his feet untill the boat came to a stop against a padded dock and he went below and throttled down. I was standing on the ramp hoping for the best and trying to look serious. Hey, it was my first sailboat and probably his first time starting the engine (removable hand crank with bicycle chain starter drive). Too bad this predated the ready availability of camcorders, it was a hoot.
Little itsy bitsy trailer wheels have to turn hig RPM to make much road speed. This coupled with overloading gives high bearing temps. Sometimes high enough to make a hiss of steam when the axles hit the water. Any voids/air space in the grease and bearings then contract and suck in water to "help" the grease turn to mayonase. Ever wonder why so many trailers with small wheels are parked at the side of the road with a wheel off, it isn't all flat tires!
Patrick
/ backing up with a cart #31
I remember a day about 30 years ago when I launched Dad's boat and forgot to put the plug in. No problem until I had driven the boat about 5 miles away to our dock, gone into the house and changed, and came back to find the back end full of water. BILGE PUMP OUT! /w3tcompact/icons/shocked.gif I found the plug (in the car), ran back to the boat, headed out full steam into the lake. The water was sucked out the drain hole. I then jumped in, plug in hand, and inserted the plug. WHEW!
About two months ago, I was waiting on someone to load their boat so I could launch mine. There was a man about 60 behind the wheel of a brand new Suburban, getting shouted directions from his son aboard his brand new Baja. The old man was pushing that trailer everyways but towards the ramp. When he started backing the trailer completely in the wrong opposite direction towards my truck, I jumped out and offered to help. He explained it was a new truck and he was not used to it. (Picture Jimmy Fallon's computer guy here - MOOOOVE!). I jumped in and had the trailer down the ramp in about 10 seconds. I think he was a little embarassed. I got a round of applause from two nearby girls in bikinis. /w3tcompact/icons/cool.gif
/ backing up with a cart #32
8ntx, Here is a relevant comment:
One of the best bilge pumps in the world is a scared man with a bucket.
Back in my US Coast Guard period I took a practical exam with disaster recovery simulations. Vessel is taking on water and all bilge pumps are failed. Is there anything better to do than disconnect the battery and take it to "higher ground" so you can make distress calls and make transmissions for DF purposes and not have the battery covered by salt water and ruined, making the radio inop.
My solution was to whip out my folding knife (on a lanyard so it can't be lost) and cut the sea water intake hose providing sea water to the heat exchanger of the fresh water cooled inboard engine at the seacock to get the most hose length. Of course you close the seacock to prevent flooding via the cut hose. With the engine running, the raw water pump and the hose you just cut is an improvised bildge pump with considerable capacity. To avoid the risk that something floating around in the bildge could plug the pump, I cut the pop top end off of a beverage can, punched holes in it with the marlinspike on my knife and put the can over the end of the hose as a strainer. After the bilge is sufficiently dewatered such that the critical portion of the emergency is past and you need another source of cooling water to the heat exchanger and the leak isn't sufficient, just open the seacock as needed to let sea water in.
I passed the exam.
Once during the 9 years I lived on my sailboat, a neighbor (also a sailboat resident) knocked on my hatch at 0530 saying something about his new sailboat sinking at the dock and wanting to borrow my portable emergency 12 volt operated bilge pump with gator clips and 20 ft of 1 1/2 inch hose. His wife detected the emergency when she got up at 0500 and noticed she was standing in water above the floorboards. He was bailing with a bucket for abouta half hour and was getting exhausted because he didn't want to inconvenience me so early in the morning but when it became clear that he was losing the battle he got over his shyness. Later, they bought an emergency bilge pump. and made some plumbing mods along the lines I had suggested when I first got toured about their new boat (but they weren't motivated to think a NEW boat could have problems like I was warning about, at the time).
On the topic of sailboats: Sailing, the art of slowly going nowhere at great expense while getting violently ill.
Sailboat, a fiberglass or wood lined hole in the water into which you throw money.
Stages of sea sickness: Stage 1, you don't feel quite right but don't want to tell anyone and have anyone's fun disturbed by taking you back to the dock. Stage 2, you feel lousy and don't care whose fun is spoiled as long as they take you back to the dock, NOW! Stage 3, you are so sick and feel sooooo bad that you are afraid you are going to die. Stage 4, You feel really truly sick and are afraid that you aren't going to die.
Patrick
/ backing up with a cart #33
Patrickg:
You'll probably get a kick out of this one. April 14th 1988, I will always remember that date. I had just purchase my first commercial fishing boat, A used 38 ft salmon seiner and was was on my initial trip with this boat. Just happened to be 18 hrs into one of those 24 hr halibut openings that they used to have. Anyway the hydraulics kick out, so I step inside to turn them back on and find the bilge hatch starting to float. Immediately turn both pumps on and jump in up to my waist in bilge try to locate leak, no luck. Did I mention we were 7 miles off shore and 32 miles from nearest help. So put out mayday to the Coast Guard and luck would have it they already have a helicopter airborne with pumps. Helicopter arrives and starts to lower the pump. In my panic I run out on deck to grab pump. Next thing I know I'm overboard. You see a big helicopter creates a lot of static electricity, that discharges down the winch cable into the first thing it touches. The kicker of this story is 10 years before I used to be a USCG crew member on these very same helicopters, and should have known better. Oh yes got back on board, pumped her out, boat was saved, ego was very bruised.
/ backing up with a cart #34
<font color=blue>I got a round of applause from two nearby girls in bikinis</font color=blue>
Now that's worth a trip to the ramp !!!!!
Cheers
/ backing up with a cart #35
Russ, AKA Kodiak, You were right, I loved the story. Isn't it a real hoot how when the roles are reversed (rescuer and rescuee) we stay to the script for that role? Pretty funny, also potentially dangerous, the static buildup can do more than make you jump like Mr. Volta's frog. Luckily you recovered and didn't have to depend on yor Bailey suit. You did carry one of those ugly mothers didn't you or was this adventure prior to their introduction/popularization?
My wife and I did ten years together working out of San Diego in costal search and rescue. We did a lot of training at the air sta but never involved directly in air ops. San Diego Coast Guard Air Station was our radio comms. We used to be some annoyed at the air guys. We'd get a call, hop aboard, and head out, then about an hour into the run a chopper would casually DASH out and take care of buisness, we were lucky if we got to continue and take the vessel under tow. Oh well, I got all the excitement I needed in just a few minutes getting a line on a 35 ft twin I/O just starting into the surf at ballast point with a family of 5 on board. In the troughs we were real close to hiting the bottom on the rocks. Another few seconds literally and we would havve had to abandon the attempt or lose our boat and crew. We got lucky. My wife was crewman towmaster that day instead of communicator or navigator and I was vessel master. I tossed the small line across their vessel and she directed them via the bullhorn to pull it in to retrieve the tow line and secure it to the anchor windlass. Meanwhile the assigned navigator, who was a whiz at manuevering the 50 ft twin diesel was doing a ballet with the throttles and shift levers to keep up close enough to work the case but not surf into the shore (real rocky). I figure we got lucky and took a strain on the line about 5-10 seconds before we either had to abandon them (no one on board liked that) or join them ashore if we didn't go down in the rocks on teh way.
I once got involved in building 20 each 38 ft single screw diesel fish boats for the Alaskan trade. All aluminum hulls. That was a hoot. A buddy was in charge of the electronics, RADAR, sounders, VHF, SSB, and on and on. He had installers from both the ranks of marine elctricians and electronic techs. What chaos, what a tower of Babel. Electricians use black for hot and white for neutral (return) while ET's use black for ground (negative) and the "other" color for hot. Lots of blown fuses, strained tempers, and little progress before he asked me to help with the RADAR installs/checkout/tuning since he was getting behind (I have commercial radiotelephone lics with ships RADAR endorsement). As soon as I figured out the problem was THE BLACK WIRE and how it couldn't be hot and ground at the same time and held a 5 min all hands seminar, everything was OK. Had to really be fastidious and absolutely insist that no wire scraps made it to the bilge. Copper, like a penny for instance, laying in the bilge would eat a hole in the aluminum hull with sea water as the electrolyte making the aluminum-copper battery. Mercury from a broken thermometer was a big no no too.
OK, just a couple more "sea stories"... San Diego Air used to tape all incoming emergency traffic and this tape got played at parties and such since it was to us, funny. Portuguese fisherman/captain on an older (wooden) tuna boat (not yet sunk to collect insurance) is taking on water and calls the Coast Guard. "Costa Guarda Coasta Guarda this is the (Witheld for privacy reasons), My boat she is a sink!!
CO of the air sta is up in a helo and has a portable drop pump. They find the vessel in distress and drop the canister packed pump straight down on the distressed vessel through the open hatch into the hold. Now in the USAF we call that a shack, i.e. ordinance perfectly on target but this wasn't a bombing sortee (well not supposed to be) Capt comes up on the VHF and says, "thanks a lot coasta guarda, now my boat shes a really sink.
I been on the other side too. Due to a late night fatique induced computational error I was a few degrees off course motoring up the coast from San Diego to Catalina Island, a trip I had often made and had stopped at many different intermediate harbours on different voyages. Anyway I ended up on the beach real close to the San Onofre nuclear poser station in a 34 ft full keel sailboat. Much luck, no rocks, no surf to speak of and the next morning at first light a Coast Guard cutter sent a rubber boat in, we ran a tow line, and at high tide with only me on board, towed the thing out through the small surf to deep water. Took a couple hits to the free standing spade rudder which bent the shaft getting through the surf but no leaks so motored to Oceanside and then to San Dieo with no further excitement.
As I taught navigation in public education courses and my wife and I were both qualified navigators for search and rescue ops, I was more than just a little embarrassed. As they say, stuff happens, even when yo aren't backing up a cart with a wheelbase much shorter than the tow vehicle (push vehicle?)
Patrick
/ backing up with a cart #36
Terry, no kidding, I had to go slow to get it right , a lot!
2897 (A64281)
2897 (A64281)
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A61573)
2016 Peterbilt 579...
2001 TAKEUCHI TL150 SKID STEER (A64279)
2001 TAKEUCHI...
UNUSED SDLANCH SDLL60 STAND- ON SKID STEER (A64280)
UNUSED SDLANCH...
213077 (A64276)
213077 (A64276)
2009 Arco Trailer 6,000 Gallon T/A Tank Trailer (A61568)
2009 Arco Trailer...
