Backhoe backhoe wont move
/ backhoe wont move #1
babydoll
bought a jd 955 at auction with front and rear bucket, front bucket does fine and rear wont move . do I need to move a valve or something jacks dont work either thanks
/ backhoe wont move #2
If the 2 backhoe hoses are well connected in the tractor, it should work otherwise there is a problem with the backhoe. The tractor has constant flow back there.
Is it the Deere 7 backhoe model?
/ backhoe wont move
it is a deere quick connect type ,, havent got it home yet dont know much about them ,, the valve body is leaking bad coming out of the top of some of the spools... front bucket works well it is probably low on fluid but the front bucket works well . thought there might be a front and rear valve or something on it it has 1000 hours on it bought it as is so I dont really know ,, thanks
/ backhoe wont move #4
Get it home, fix the leaks, make sure all connections are secure and then see what happens... congrats on the new to you Deere 955.. that's a popular model and 1000 hours isn't that much.. hope it's a fairly easy fix..:drink: (fingers crossed)
/ backhoe wont move
found out that there is a problem with the return line it swells up when u start the engine . the oil for some reason wont go back to the pump valve stuck or some thing checkd the hoses and they are ok plenty of pressure :confused:
/ backhoe wont move #6
If the return line isn't allowing fluid to return then something is blocking it. Take some pictures and post them.. Maybe a quick connection isn't seated.
I'd disconnect the return line and direct the flow into a bucket and see if the line really is not allowing flow.
/ backhoe wont move
did the bucket thing ,, that is how i found the problem,,
got it working and the leaks stopped ,,, there is a valve under the seat on the left side it was turned out about all the way counter clodkwise I turned it all the way in clock wise and then backed it about half way out and eveything went too normal leaks and all. as I said I just got it home yesterday and had not had much time too fool with it.
now i have some lights too fix degrease it and than grease it things are looking up thanks :thumbsup::thumbsup::thumbsup:
/ backhoe wont move #8
Good going bd. Those 955's are nice..;)
BTW: your handle.... do you have sheep? southdown babydolls?
This is one of ours...
/ backhoe wont move
no sheep , use to have angora goats ,,, no more , too many dogs
/ backhoe wont move
another question???
backhoe seems weak, . where is the pressure adjustment on the JD 7 backhoe? I have 2400 psi coming from the tractor,, thanks bd
/ backhoe wont move #11
another question???
How weak? Will it pick up several hundred pounds? If you curl the bucket and place it on the ground then, with slight down pressure on the boom, uncurl the bucket carefully..does it pick up the back of the tractor? Does the relieve valve do it's job at the right pressure? Do you have a service manual? How much experience do you have with small backhoes?
Might be time to replace hydraulic fluid and filters. There are ways to test hydraulic pressures.
/ backhoe wont move
bucket wont uncurl all the way
fluid and filter r new
i am going to check the pressure going to the bucket or boom, just wondered where the adjustment for the hoe is,, tractor pressure should be good with 2400 psi .
no service manual.. is there a place to put a gauge on the valve chest?
/ backhoe wont move #14
I turned it all the way in clock wise and then backed it about half way out and eveything went too normal /QUOTE]
Close the valve.:)
I just assumed he tried that Egon.. maybe I shouldn't assume heh?
2015 Chevrolet Impala Sedan (A64557)
2015 Chevrolet...
48” Titan Skid Steer Root Grapple – SSQA – Excellent Condition
48” Titan Skid...
2016 Freightliner M2 106 Ambulance (A64556)
2016 Freightliner...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
2018 Tycrop Vector Belt VB-16H Sand Belt (A64194)
2018 Tycrop Vector...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
