Backhoe Backhoe, with or without loader?
   / Backhoe, with or without loader? #11
Yep, why be normal?
That tractor weighed 6300 pounds, with all 4 tires filled, but the little hoe could still pick up the back end push it forward.
Thanks for the information! I wasn't planning on a loader because I have a old Farmall 450 with a loader I use now. Sorry I didn't mention that earlier. I will most likely end up selling the Farmall & putting a loader on but the old girl comes in handy at times!
   / Backhoe, with or without loader? #13
I'd have to guess that the only way you'd get a hoe with out a loader to fit your machine is with a 3pt mounted one. I'm pretty sure all the major manufactures require a loader to tie in with the sub-frame.
Another option to consider is a small used mini-ex. You should be able to pick up a decent one for the same or less than what it would cost for both a loader and hoe for your L. Way more efficient at digging but you loose considerably on ground speed compared to a backhoe
2003 Pierce Tilt Cab Foam Pumper Fire Truck (A54814)
2003 Pierce Tilt...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A55852)
2014 Ford F-150...
2016 PETERBILT PB337 FLATBED TRUCK (A57192)
2016 PETERBILT...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A53843)
2006 V.E...
Hercules Pesticide Applicator Tank with Nozzle (A55852)
Hercules Pesticide...
