backhoe valve repair
/ backhoe valve repair #1
preacher1
Meta, Missouri
LS MT342HC
The valve boom/dipper stick on my bh1575 landpride backhoe attachment does not return when released. Is this a valve problem or spring or something else? Land pride no longer makes a backhoe and are no help.
/ backhoe valve repair #2
Majority of directional valves have the centering springs located under a cap or cover on the end opposite of where the linkage connects. Can you post a couple of pictures of your valve assembly?
/ backhoe valve repair #3
Yep, like oldnso said. Pull the cap, clean polish etc. Probably some crap in there.
Also you could remove the push/pull linkage and slide out the valve barrel and again clean polish.
The tiniest bit of grit might be what is the cause.
Don't sand or grind, simply polish as this is a close machined fit.
2011 Chevrolet Impala Sedan (A66738)
2011 Chevrolet...
1996 International 4700 (A64127)
1996 International...
2013 Ford Transit Connect Cargo Van (A66736)
2013 Ford Transit...
DYNAPAC CP142 ROLLER 9 WHEEL PNEUMATIC ROLLER (A67714)
DYNAPAC CP142...
2021 Wacker Neuson G25 Quiet Power 20kW Towable Generator (A66734)
2021 Wacker Neuson...
CATERPILLAR PC306 PLANER (A65053)
CATERPILLAR PC306...
