Backhoe Tree Root Cutter Winter Project
/ Backhoe Tree Root Cutter Winter Project #41
Personally I'd stick with the original design you had - the current iteration looks much less workable in terms of it's attachment method.
/ Backhoe Tree Root Cutter Winter Project #42
Ok I'm out of the lurking mode to add my 2 cents. I recently attempted similar project using a 3/8 x 4" x 20 inch piece of steel sharpened on one edge. I drilled 3 holes on outside edge of hoe bucket to mount cutter. Unfortunatley the first time I used it the cutter bent badly. Probably had too much length sticking out and too thin metal. Now I have purchased a plow share from Tractor Supply hoping since it is thicker and probably heat treated it will work. Will have to wait to try it until get new cylinder for hoe that I bent trying to break up huge stump. - (Simple abuse not related to cutter) Best luck with project.
Mud puppy
/ Backhoe Tree Root Cutter Winter Project #43
Seems the ones I've seen on trackhoes are rigid and attach to dipper stick. Bucket is curled in to expose ripper tooth. Doesn't get in the way of digging and no removal of bucket. Try a search on stump ripper or splitter or similar.
Thanks, I will search that. Never seen a rigid model but that makes sense. Had a suggestion that I mount one on my dipperstick in the same position as to where a thumb is mounted. Got thinking about that scenerio & said "hey,maybe". Your thoughts ?????
/ Backhoe Tree Root Cutter Winter Project #45
Check out the Land Pride Backhoe site, they have show a tree root/frost ripper tooth that mounts onto the back of the bucket. Might be another way of solving the problem.
HTH. Andrew
Banjo....
Thanks for the Link.....
I see post #1, welcome to TBN.
You will enjoy yourself here, I'm sure of it !!
Good to have another Cdn on board as well.
/ Backhoe Tree Root Cutter Winter Project #47
GG,
thanks for the welcome. I've looked at the odd post over here when it comes up in a google search. I "resisted" joining as I already spend enough time on the Machine Builders Forum as it is /forums/images/graemlins/wink.gif.
The LandPride operator and parts manuals are available on their site in pdf. They have pretty much all the info you'd need to make one up. I used them as one reference for the hoe I designed and built this year.
The Fabco reference in the tooth blade article reminded me of them. They (and others) sell "scarifier" teeth and tips, that are made to be used this way. There was a guy selling stuff on ebay at good prices. Someone I know (in the US) bought his teeth from them. Fabco Scarifier Teeth
The teeth I used on my hoe came from Hensley, who also make shanks.
Good info, I've got it on the list to make one up for mine, but there's a few things in the pipe before it.
FWIW. Andrew
I went to the LandPride Site but unfortunately couldn't find the Tooth then got busy & put it on the back burner. I e-mailed Ag-Way in Ontario & gave him my specs, he replied saying they could possibly supply me with one but to call them. You know anything about them & where's Merrickville ?? Machine Builders Forum, hmmm, haven't spent any time there. Have you bought Landpride Items here in Canada ??
/ Backhoe Tree Root Cutter Winter Project #49
It's in their manuals, backhoe section, parts (might be in the operators one too). Landpride Parts Manual (pdf) . It's right at the back, page 46. The picture I pasted in above is from their backhoe brochure. I've never bought anything from Landpride, just looked at their info, and I think perhaps some of their hoes (they're marketed under a number of names in various OEM deals I think).
Merrickville, is about 60km south of Ottawa.
The Machine Builders Net forum has been a lot of fun and is full of great information. It seems to have attracted a remarkable cadre of people who love to build things, and help others do it to. Be warned though ... it's habit forming /forums/images/graemlins/grin.gif !
cheers, Andrew
/ Backhoe Tree Root Cutter Winter Project #50
Behind the bucket, tooth would just follow in it's path. At thumb position, I trhink it would be awkward at best to rip with due to bucket hitting bottom Maybe if it was long enough it would work in front, but that increases leverage to break it off or damage dipper. Good luck.
/ Backhoe Tree Root Cutter Winter Project #51
FWIW, the LandPride one hooks onto the link that joins the bucket to the bucket cylinder. I presume that with the bucket curled, it's sufficiently out of the way to use the ripper, and you can dig well enough with it on too. It goes on with one pin, so it would be easier to put on and off than changing a bucket (you'd like to think).
I haven't used one, so was offering this only from a "design alternative" point of view.
/ Backhoe Tree Root Cutter Winter Project #52
As another alternative...
How about a design that has something similar to a "thumb" that would swing down in front of the bucket when needed, and be quickly pinned back up against the stick when not needed?
I see a fuzzy picture in my mind of how something like this could be done, while still allowing for worst case movement of the bucket without damage resulting...
Just food for thought... /forums/images/graemlins/smile.gif
Andrew...
I'm really liking this idea.....
Called AgWay in Ontario today & they quoted me $450 plus shipping for theirs. I like building my own stuff but I'm also a realist, if I can't get good scrap cheap many times it just as cheap to buy although not as much fun. I'm gonna investigate the landpride design further. Thanks..
Henro..
Did you see my post with the tooth on the bucket idea, I asked what you thought of that ?? Also there was a suggestion about replacing the thumb arm with the cutter so I'd like your thiughts there as well. Love to hear what you think, Bud
/ Backhoe Tree Root Cutter Winter Project #55
GoodGuy,
Yes, I guess I did see that post and you know what they say, the mind is the second thing that goes... /forums/images/graemlins/blush.gif
Myself, I don't think I would want to have anything that went out longer than the teeth of my bucket, when the bucket is postioned so the teeth are in line with the axis of the stick, if that makes any sense.
The reason being that leverage would be lost. Now maybe there could be some gain in leverage if the end of the knife was stuck in the ground. Have not thought about that. But when it was in free space and just acting against the root, I think a long knife would be a losing propostion.
I keep coming back to something that would be easily pinned to the bucket and extend the length of the bucket, stopping at the end of the bucket, in front of the teeth, and done in a way that it could be sort of latched over the outside bucket teeth for stability (essentially a 3-point mount).
If only used in a manner that would cause the cutter to be pushed against the bucket, then it probalby could be held in place by a spring or something that wrapped around under the bucket on the outside...or maybe just somehow pinned in place by one more pin of some kind.
Just thinking out loud. My gut is telling me that some sort of simple, and effective solution is there.
I am not sure that using a "thumb like" device is the solution now, after reading a thread where the poster's (Sorry, I can see the pictures in my mind, but the name has vanished /forums/images/graemlins/blush.gif) thumb pivot point was bent with use, and it was 3/4 inch steel.
Anyway, I think there is promise in your idea so don't write it off to quickly...I know I have wished for something to cut roots better than my 9" bucket. But to be useful to me personally it would have to go on and off quickly. I doubt that having a couple holes in the bucket side would hurt bucket performance too much.
I have a picture in my mind of something that slips over the bucket teeth, then rotates so that mounting tabs could be pinned to the bucket sides...the picture is a little blurry though... /forums/images/graemlins/smile.gif
Thanks Bud !!!
I always appreciate your thoughts
/ Backhoe Tree Root Cutter Winter Project #57
I too have struggled with ripping roots with my backhoe bucket. I considered trying to fabricate a ripper tooth, but since Struck Corp makes one for my Magnatrac tractor I figured it would be easier for me to just buy the one that they make. We got some good weather today so I had a chance to put it together and mount it on the backhoe. Attached are a few pix. I didn't get a chance to play with it yet, but I'll report on how it works after I get to use it some.
Here's the bucket coming off. Its not too heavy (I can pick it up). A couple of minutes.
John
/ Backhoe Tree Root Cutter Winter Project #58
Here's a pic of the ripper tooth. You can see that it is basically a holder that mounts on the backhoe and a bolt on tooth. Actually it comes with two teeth one is a serrated slicer type of plow tooth and the other is a curved plow ripper. I've selected the serrated blade for my first tests of the new "weapon" /forums/images/graemlins/wink.gif
John
/ Backhoe Tree Root Cutter Winter Project #59
Here is a pic of the ripper tooth going on the backhoe. Its lighter than the bucket so its pretty easy to get it up and pinned on. Again only took a couple of minutes.
Ready for action /forums/images/graemlins/smile.gif
/ Backhoe Tree Root Cutter Winter Project #60
Eric, my dad built one of those in the mid/ early 70's and it worked ok but would have been better with another set of bars to actually cut the root like a scissor. Worked best on taller trees with more leverage to topple over once the root base was cut. I agree with some of the others about having to remove the soil or at least, loosen it up. I have a tendancy to just loosen the soil with the back hoe to limit clean up but in a majority of cases the dirt had to be removed. Best bet is to get it with a full tree so that the trunk can be used like a large wrench. Be careful, have fun. /forums/images/graemlins/grin.gif
